Libcamera issues on fresh install
  • DietPi version |
    G_DIETPI_VERSION_CORE=8
    G_DIETPI_VERSION_SUB=24
    G_DIETPI_VERSION_RC=1
  • Distro version | bookworm 1
  • Kernel version | Linux DietPi 6.1.21+ #1642 Mon Apr 3 17:19:14 BST 2023 armv6l GNU/Linux
  • Architecture | armhf
  • SBC model | RPi B (armv6l)
  • Power supply used | USB 3.0 port
  • SD card used | SanDisk Transcend 8GB
  • Camera | Arducam OV5647
  • Software title | libcamera-apps
  • Was the software title installed freshly or updated/migrated? | fresh
  • Bug report ID |
  • Installed a fresh version of dietpi
  • installed libcamera-apps
  • im not sure ive never used it before?
  • Recieving: message below
# libcamera-hello
ERROR: libcamera-apps currently only supports the Raspberry Pi platforms.
Contributions for other platforms are welcome at https://github.com/raspberrypi/libcamera-apps
I know im missing something obvious so thank you in advance.
What camera module do you use?
I am using an Arducam OV5647
They provide their own installation script for this cam and also you need to enable some overlays:
https://docs.arducam.com/Raspberry-Pi-Camera/Motorized-Focus-Camera/Quick-Start-Guide/OV5647-Motorized-Focus-Camera/
That seemed to fix it.
which is weird since I had previously used the same set of commands here libcamera and libcamera-apps - Arducam Wiki
Maybe it just needed a reinstall?
Thank you for your help/time
