Letsencrypt renew / cron issue
    G_DIETPI_VERSION_CORE=8
    G_DIETPI_VERSION_SUB=5
    G_DIETPI_VERSION_RC=1
    bullseye
  • Kernel version | uname -a
    5.10.110-meson64 #22.05.1 SMP PREEMPT Sat May 28 07:50:27 UTC 2022 aarch64 GNU/Linux
    Odroid C4/HC4 (aarch64)
    Nextcloud, Letsencrypt
    No
    I don’t know
    e913f5ea-44de-4789-a438-5fa0c3af6af0
  1. Letsencrypt certificate is running out of validity
  2. Certbot runs via cron to update it
  • New Certificates get installed
  • Certbot doesn’t update the certificates
  • I checked whether the cron daemon runs or not with the command:
sudo journalctl -u cron.service | grep certbot
  • which result was
Jun 19 00:00:01 my.domain.com CRON[1458679]: (root) CMD (test -x /usr/bin/certbot -a ! -d /run/systemd/system && perl -e ‘sleep int(rand(43200))’ && certbot -q renew)
Jun 19 12:00:02 my.domain.com CRON[1496091]: (root) CMD (test -x /usr/bin/certbot -a ! -d /run/systemd/system && perl -e ‘sleep int(rand(43200))’ && certbot -q renew)
Jun 20 00:00:01 my.domain.com CRON[1532602]: (root) CMD (test -x /usr/bin/certbot -a ! -d /run/systemd/system && perl -e ‘sleep int(rand(43200))’ && certbot -q renew)
Jun 20 12:00:01 my.domain.com CRON[1570024]: (root) CMD (test -x /usr/bin/certbot -a ! -d /run/systemd/system && perl -e ‘sleep int(rand(43200))’ && certbot -q renew)
  • if i run the following command manually, everything works fine but I want it to work automatically right
sudo certbot renew
Short question, was the certificate already expired? Or was there still some days left? That’s basically a certbot own functionality to renew a certificate only if needed.
Hey @Joulinar ,
the certificate was already expired.
The certificate if renewed via systemd timer instead of via cron job:
systemctl status certbot.timer
journalctl -u certbot
I will have to check it again and don’t fix it manually if it occurs again. the certbot runs automatically but the certificate somehow wasn’t renewed by it.
Did you tried to restart the web server before going to recreate the certificate manually? We had a case once where the certificate was correctly renewed by certbot but a web server restart was needed to have it accepted
Ah right, with Lighttpd the restart is still required.
:smile: you got me. That is my problem then. Nevertheless it is really bad for me e.g. if the cert runs out during vaca and i can’t access my privat network. I have to find a workaround then
Solved with: v8.6 · MichaIng/DietPi@70f7fa2 · GitHub
Run this:
[[ -d '/etc/letsencrypt/renewal-hooks/deploy' ]] || G_EXEC mkdir -p /etc/letsencrypt/renewal-hooks/deploy
G_EXEC eval 'echo -e '\''#!/bin/dash\nsystemctl reload lighttpd'\'' > /etc/letsencrypt/renewal-hooks/deploy/dietpi-lighttpd.sh'
G_EXEC chmod +x /etc/letsencrypt/renewal-hooks/deploy/dietpi-lighttpd.sh
Needs to be tested whether a “reload” is sufficient or a “restart” of the service required.
@MichaIng
I just tested it with a manuel forced renewal.
reloading lighttpd was sufficient. THanks
Many thanks for testing!
