usually this should not be needed. We have quite a number of systems running this configuration without issue. @MichaIng any idea?
@kazgor
A bit of topic, but usually Nginx proxy manager should be the one who manage SSL certificates and not the backend web server.
Jappe
8 February 2023 17:16
22
A little side note:
service lighttpd force-reload actually reloads the config without the need of restarting the service, so systemctl restart lighttpd.service is not necessary
Can you try to create the file manually and access it via plain HTTP:
mkdir -p /var/www/.well-known/acme-challenge
echo 'this works' > /var/www/.well-known/acme-challenge/xclDxBCplrSQSNvv9klstrMm16SUjsf7ekMkTU6RldE
curl -IL 'http://mydomain.org/.well-known/acme-challenge/xclDxBCplrSQSNvv9klstrMm16SUjsf7ekMkTU6RldE'
and via browser.
Totila
10 February 2023 07:19
24
Isn’t this the same that is done when HTTPS redirect is disabled as per above?
I can only test your snippet when the next renewal is pending. For now all is working as the renewal was done manually.
This can be done at any time. It’s a manual test like letsencrypt would do. It should just verify if you are able to download the file yourself.
Totila
10 February 2023 11:36
26
Ah, understood.
The above results in:
HTTP/1.1 301 Moved Permanently
Location: https://mydomain.org/.well-known/acme-challenge/xclDxBCplrSQSNvv9klstrMm16SUjsf7ekMkTU6RldE
Date: Fri, 10 Feb 2023 11:35:03 GMT
Server: lighttpd/1.4.59
HTTP/2 200
content-type: application/octet-stream
accept-ranges: bytes
etag: "4127794750"
last-modified: Fri, 10 Feb 2023 11:35:01 GMT
content-length: 11
strict-transport-security: max-age=31536000; includeSubdomains
date: Fri, 10 Feb 2023 11:35:03 GMT
server: lighttpd/1.4.59
Looks all perfectly fine, also the content-length matches the actual “this works” string (+ line ending) of the file.
I verified on my home server and dietpi.com that HTTPS redirect is not an issue and HTTP/2 isn’t eiter.
See also docs: Challenge Types - Let's Encrypt
Our implementation of the HTTP-01 challenge follows redirects, up to 10 redirects deep. It only accepts redirects to “http:” or “https:”, and only to ports 80 or 443.
All fine in your case, a single redirect to (same) hostname to HTTPS on port 443, just standard.
Can you access that URL as well via browser from outside your LAN? E.g. try with mobile phone and mobile Internet used. It should show “this works” in browser window. You can create another file with shorter name, to avoid typing the long random string .
Totila
10 February 2023 21:19
28
Yes I can open it without issue:
The web browser redirects to HTTPS and then offers the download of the file. Content is ‘this works’
Okay, I’ve no idea then why the ACME server would fail to do the same. I will try to replicate with Lighttpd. This is a Bullseye image on which hardware?
Tested on my RPi3B+ 32bit without issues
root@DietPi3:~# certbot renew --force-renewal
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /etc/letsencrypt/renewal/my-domain.com.conf
Renewing an existing certificate for my-domain.com
Running deploy-hook command: /etc/letsencrypt/renewal-hooks/deploy/dietpi-lighttpd.sh
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/my-domain.com/fullchain.pem
Congratulations, all renewals succeeded:
/etc/letsencrypt/live/my-domain.com/fullchain.pem (success)
root@DietPi3:~#
Btw, can you share some more information on your system
Required
DietPi version | cat /boot/dietpi/.version
Distro version | echo $G_DISTRO_NAME $G_RASPBIAN
Kernel version | uname -a
Totila
11 February 2023 15:12
32
Now that I have renewed the certificate by hand, certbot renew --force-renewal also works on my PI.
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=13
G_DIETPI_VERSION_RC=2
G_LIVE_PATCH_STATUS[1]=‘not applicable’
Bullseye
1
uname -a
Linux DietPi 5.15.84-v7+ #1613 SMP Thu Jan 5 11:59:48 GMT 2023 armv7l GNU/Linux
interesting. Usually, the automatic renewal process is working same way and should work next time.
Totila
11 February 2023 18:53
34
That’s what I thought.
I will keep you posted next time the renewal day is near.
t.o
14 March 2025 03:49
35
Was there ever a resolution for this?
My automatic certbot renewals have also been failing for a while now. Even with disabling the mods and https redirects, etc., the http-01 challenge always fails.
When I manually create the test file and try to retrieve it from the local or an external network, I get a 404 error. When I ‘curl’ the file directly on my dietpi machine I get everything correctly if https, proxy, etc., are disabled. Once I enable them again, I get “HTTP/1.1 301 Moved Permanently” as the first line from ‘curl’.
Renewal does work if I do this:
dietpi-services stop lighttpd
certbot renew --standalone
My other services are accessible - Nextcloud, Emby, and Syncthing GUI
What should the file permissions be on /var/www and subdirectories, especially /var/www/.well-known? Mine are owned by ‘root:root’
Running
lighttpd 1.4.69 configured to run as ‘www-data:www-data’ on port 80
dietpi v9.9.0
certbot 2.1.0
This topic is 2 years old. Please open an own one providing all necessary information and logs
