Keyboard seems to be not detected right after installation RPI CM4
  • DietPi version | v9.4.2
  • Distro version | recent Bookworm image downloaded from the dietpi homepage 3 weeks ago. can’t cat the concrete version
  • Kernel version | …
  • Architecture | ARMv8
  • SBC model | Raspberry PI Compute 4 mounted on a CM IO board
  • Power supply used | Power supply set to 12V
  • SD card used | no SD card, image installation via rpibootsetup script and serial interface
    yes
Installation of the image with Praspberry PI Imager. Right after reboot try to login directly via keyboard and display in the console. No ssh.
After pressing Enter I should see the characters for the username I’m typing into the keyboard.
Hitting enter has no effect on the console screen. I don’t see any characters at all.
So you see this screen:
grafik
and after hitting enter it does not change to:
grafik
Did you try another keyboard / USB port?
Yes, it’s exactly the way you described it with the screenshots.
I tried another keyboard and another SUB port. Still the same.
Bother keyboards work on my laptop.
Can you login via SSH or do you have an UART adapter, to have a look into dmesg output? Otherwise it will be hard to track this down further.
I’m managed to get one and will check via serial.
Meanwhile I’ve installed Raspberry Pi OS lite. Worked fine. Could log in etc. So it shouldn’t be hardware/power issue.
Same here. SSH/Serial works but Keyboard directly plug into expansion board(tried many kind of, besides Official CM4 IO Boards) NOT working. PiOS is alright.
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[    0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
[    0.000000] random: crng init done
[    0.000000] Machine model: Raspberry Pi Compute Module 4 Rev 1.0
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[    0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
[    0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[    0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 996912
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:3840x2160M@30 smsc95xx.macaddr=E4:5F:01:6B:8A:C6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  root=PARTUUID=6b2e6707-02 rootfstype=ext4 rootwait net.ifnames=0 logo.nologo console=tty1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[    0.000000] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 39744 entries in 156 pages
[    0.000000] ftrace: allocated 156 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000165] Console: colour dummy device 80x25
[    0.000423] printk: console [tty1] enabled
[    0.000457] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000475] pid_max: default: 32768 minimum: 301
[    0.000540] LSM: Security Framework initializing
[    0.000656] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.000692] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001333] cgroup: Disabling memory control group subsystem
[    0.002375] cblist_init_generic: Setting adjustable number of callback queues.
[    0.002392] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.002476] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.002558] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.002767] rcu: Hierarchical SRCU implementation.
[    0.002777] rcu: 	Max phase no-delay instances is 1000.
[    0.003383] EFI services will not be available.
[    0.003647] smp: Bringing up secondary CPUs ...
[    0.004214] Detected PIPT I-cache on CPU1
[    0.004302] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[    0.004821] Detected PIPT I-cache on CPU2
[    0.004875] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[    0.005369] Detected PIPT I-cache on CPU3
[    0.005423] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[    0.005484] smp: Brought up 1 node, 4 CPUs
[    0.005525] SMP: Total of 4 processors activated.
[    0.005534] CPU features: detected: 32-bit EL0 Support
[    0.005542] CPU features: detected: 32-bit EL1 Support
[    0.005552] CPU features: detected: CRC32 instructions
[    0.005621] CPU: All CPU(s) started at EL2
[    0.005639] alternatives: applying system-wide alternatives
[    0.006663] devtmpfs: initialized
[    0.012062] Enabled cp15_barrier support
[    0.012102] Enabled setend support
[    0.012217] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.012241] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.021373] pinctrl core: initialized pinctrl subsystem
[    0.021830] DMI not present or invalid.
[    0.022182] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.023812] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.023943] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.024373] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.024425] audit: initializing netlink subsys (disabled)
[    0.024553] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[    0.024829] thermal_sys: Registered thermal governor 'step_wise'
[    0.024871] cpuidle: using governor menu
[    0.025045] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.025136] ASID allocator initialised with 32768 entries
[    0.025219] Serial: AMBA PL011 UART driver
[    0.031063] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.044134] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[    0.048139] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[    0.057063] KASLR enabled
[    0.073602] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.076082] SCSI subsystem initialized
[    0.076214] usbcore: registered new interface driver usbfs
[    0.076245] usbcore: registered new interface driver hub
[    0.076279] usbcore: registered new device driver usb
[    0.076485] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.076598] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[    0.076761] pps_core: LinuxPPS API ver. 1 registered
[    0.076772] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.076789] PTP clock support registered
[    0.077324] vgaarb: loaded
[    0.077714] clocksource: Switched to clocksource arch_sys_counter
[    0.077992] VFS: Disk quotas dquot_6.6.0
[    0.078033] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.078118] FS-Cache: Loaded
[    0.078203] CacheFiles: Loaded
[    0.082318] NET: Registered PF_INET protocol family
[    0.082683] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.084649] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.084741] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.084761] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.084872] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.085921] TCP: Hash tables configured (established 32768 bind 32768)
[    0.086100] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.086151] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.086356] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.086838] RPC: Registered named UNIX socket transport module.
[    0.086853] RPC: Registered udp transport module.
[    0.086861] RPC: Registered tcp transport module.
[    0.086869] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.086886] PCI: CLS 0 bytes, default 64
[    0.088184] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.088405] kvm [1]: IPA Size Limit: 44 bits
[    0.088979] kvm [1]: vgic interrupt IRQ9
[    0.089087] kvm [1]: Hyp mode initialized successfully
[    0.551890] Initialise system trusted keyrings
[    0.552224] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.555506] zbud: loaded
[    0.556824] NFS: Registering the id_resolver key type
[    0.556855] Key type id_resolver registered
[    0.556864] Key type id_legacy registered
[    0.556923] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.556936] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.557617] Key type asymmetric registered
[    0.557632] Asymmetric key parser 'x509' registered
[    0.557674] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.557834] io scheduler mq-deadline registered
[    0.557846] io scheduler kyber registered
[    0.558734] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[    0.562826] gpio-507 (ant1): hogged as output/high
[    0.564127] gpio-511 (ant2): hogged as output/low
[    0.564766] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    0.564788] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    0.564832] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    0.564874] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
[    0.565574] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    0.565589] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.565601] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    0.565643] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    0.565785] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.567318] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.567438] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[    0.567535] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[    0.567581] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[    0.893726] brcm-pcie fd500000.pcie: link down
[    0.893801] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.893825] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.893879] pci_bus 0000:01: busn_res: [bus 01] is released
[    0.894199] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[    0.894763] simple-framebuffer 3e267000.framebuffer: framebuffer at 0x3e267000, 0x960000 bytes
[    0.894779] simple-framebuffer 3e267000.framebuffer: format=a8r8g8b8, mode=1920x1280x32, linelength=7680
[    0.899155] Console: switching to colour frame buffer device 240x80
[    0.903183] simple-framebuffer 3e267000.framebuffer: fb0: simplefb registered!
[    0.908816] iproc-rng200 fe104000.rng: hwrng registered
[    0.909091] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.909881] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    0.915659] brd: module loaded
[    0.919666] loop: module loaded
[    0.920116] Loading iSCSI transport class v2.0-870.
[    0.922596] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    0.981786] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    0.982379] usbcore: registered new interface driver r8152
[    0.982437] usbcore: registered new interface driver lan78xx
[    0.982489] usbcore: registered new interface driver smsc95xx
[    0.982805] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.982974] dwc_otg: FIQ enabled
[    0.982979] dwc_otg: NAK holdoff enabled
[    0.982983] dwc_otg: FIQ split-transaction FSM enabled
[    0.982991] Module dwc_common_port init
[    0.983233] usbcore: registered new interface driver uas
[    0.983289] usbcore: registered new interface driver usb-storage
[    0.983420] mousedev: PS/2 mouse device common for all mice
[    0.986134] sdhci: Secure Digital Host Controller Interface driver
[    0.986176] sdhci: Copyright(c) Pierre Ossman
[    0.986490] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.988820] ledtrig-cpu: registered to indicate activity on CPUs
[    0.988979] hid: raw HID events driver (C) Jiri Kosina
[    0.989076] usbcore: registered new interface driver usbhid
[    0.989101] usbhid: USB HID core driver
[    0.989249] bcm2835_vchiq fe00b840.mailbox: there is not valid maps for state default
[    0.993445] NET: Registered PF_PACKET protocol family
[    0.993549] Key type dns_resolver registered
[    0.994223] registered taskstats version 1
[    0.994287] Loading compiled-in X.509 certificates
[    0.994762] Key type .fscrypt registered
[    0.994789] Key type fscrypt-provisioning registered
[    1.002132] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.002535] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.002647] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    1.008939] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.009174] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.009852] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.009887] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.036625] of_cfs_init
[    1.036718] of_cfs_init: OK
[    1.075938] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[    1.076130] Waiting for root device PARTUUID=6b2e6707-02...
[    1.116510] mmc1: new high speed SDIO card at address 0001
[    1.137673] mmc0: new DDR MMC card at address 0001
[    1.138244] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB
[    1.139943]  mmcblk0: p1 p2
[    1.140243] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB
[    1.140676] mmcblk0boot0: mmc0:0001 BJTD4R 4.00 MiB
[    1.142172] mmcblk0boot1: mmc0:0001 BJTD4R 4.00 MiB
[    1.143387] mmcblk0rpmb: mmc0:0001 BJTD4R 4.00 MiB, chardev (242:0)
[    1.159319] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    1.159413] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.162011] devtmpfs: mounted
[    1.166515] Freeing unused kernel memory: 4160K
[    1.169805] Run /sbin/init as init process
[    1.169831]   with arguments:
[    1.169835]     /sbin/init
[    1.169839]   with environment:
[    1.169843]     HOME=/
[    1.169847]     TERM=linux
[    1.362497] systemd[1]: System time before build time, advancing clock.
[    1.441847] NET: Registered PF_INET6 protocol family
[    1.444318] Segment Routing with IPv6
[    1.445841] In-situ OAM (IOAM) with IPv6
[    1.479602] systemd[1]: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    1.482993] systemd[1]: Detected architecture arm64.
[    1.494424] systemd[1]: Hostname set to <DietPi>.
[    1.827007] systemd[1]: Queued start job for default target graphical.target.
[    1.847506] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    1.851870] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    1.855980] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    1.859935] systemd[1]: Created slice user.slice - User and Session Slice.
[    1.863691] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    1.867449] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    1.871548] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    1.875316] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-6b2e6707\x2d01.device - /dev/disk/by-partuuid/6b2e6707-01...
[    1.879047] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[    1.882749] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    1.886515] systemd[1]: Reached target paths.target - Path Units.
[    1.890288] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[    1.894118] systemd[1]: Reached target slices.target - Slice Units.
[    1.897992] systemd[1]: Reached target swap.target - Swaps.
[    1.901908] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    1.906247] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    1.910400] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    1.915309] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    1.919832] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    1.924412] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    1.929521] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    1.934160] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    1.938768] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    1.958005] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    1.965511] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    1.973335] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    1.981616] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    1.991899] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    2.000722] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    2.010967] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    2.020256] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    2.029322] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    2.038775] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    2.048946] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    2.052508] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[    2.061599] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    2.070916] systemd[1]: Starting systemd-fsck-root.service - File System Check on Root Device...
[    2.082371] systemd[1]: Starting systemd-journald.service - Journal Service...
[    2.093578] fuse: init (API version 7.37)
[    2.097992] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    2.107220] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    2.119445] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    2.126646] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    2.133474] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[    2.140920] i2c_dev: i2c /dev entries driver
[    2.145725] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[    2.153072] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    2.160150] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    2.163184] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[    2.169301] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    2.172549] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[    2.178418] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    2.181343] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[    2.187667] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    2.190812] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    2.196849] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    2.200114] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[    2.207604] systemd[1]: Started systemd-journald.service - Journal Service.
[    2.376149] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    2.883661] mc: Linux media interface: v0.10
[    2.889873] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    2.954363] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    2.954698] [vc_sm_connected_init]: start
[    2.961656] videodev: Linux video capture interface: v2.00
[    2.975568] [vc_sm_connected_init]: installed successfully
[    2.976190] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
[    2.976262] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    2.976817] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
[    3.054864] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    3.059183] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.076319] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    3.091650] rpivid feb10000.codec: Device registered as /dev/video19
[    3.092461] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    3.178778] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    3.178835] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    3.184369] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.201828] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    3.201870] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    3.210816] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    3.210855] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    3.220326] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    3.220375] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    3.226484] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.238419] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    3.238485] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    3.290240] brcmfmac: F1 signature read @0x18000000=0x15264345
[    3.295577] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    3.316110] usbcore: registered new interface driver brcmfmac
[    3.363508] Console: switching to colour dummy device 80x25
[    3.378158] systemd-journald[150]: Received client request to flush runtime journal.
[    3.436720] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[    3.438144] Registered IR keymap rc-cec
[    3.438272] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[    3.438374] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[    3.445923] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[    3.448397] Registered IR keymap rc-cec
[    3.448516] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[    3.448731] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
[    3.456099] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[    3.456409] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[    3.456603] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[    3.456774] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[    3.456953] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[    3.457078] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[    3.457250] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[    3.463947] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    3.518033] vc4-drm gpu: [drm] The core clock cannot reach frequencies high enough to support 4k @ 60Hz.
[    3.518059] vc4-drm gpu: [drm] Please change your config.txt file to add hdmi_enable_4kp60.
[    3.544818] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[    3.578137] Console: switching to colour frame buffer device 480x135
[    3.620547] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[    4.052076] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[    4.053162] bcmgenet fd580000.ethernet eth0: Link is Down
[    8.131000] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[    8.131061] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
And I found an Error:[ 0.567438] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
Is brcm-pcie driver caused this problem?
according to Several warnings on boot those “supply not found” warnings should be ok
i think the " brcm-pcie fd500000.pcie: link down" means there is nothing connected to the PCI controller. In case you haven’t aimed to connect something via PCI this should be also fine i assume. Especially, since the PCI and USB host controller are fully independent on the CM4 (in comparison to the RPI 4 Model B, see section 2.3. in the CM4 datashet).
