With 2 RPi5, where I set up dietpi with a workaround described here in the forum (OS installation on an RPi4 …), I once displayed the kernel used with uname -a.
root@adsb-feeder-falconwings:~# uname -a
Linux adsb-feeder-falconwings 6.6.31+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
I would like to switch to the current RPi5 kernel.
(Linux adsb-falconcrest-stage2 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux)
This should actually be possible with dietpi-config/Advanced options/RPi kernel choice. Unfortunately, it does not matter whether I select yes or no, the kernel does not change.
Could this be due to the “beta” installation of DietPi on the RPi5?
The kernel swap works fine on another RPi5 that I recently installed.
Thanks
