temp
January 26, 2026, 7:45am
1
Hi everyone,
I’m trying to set up my BOSE Bluetooth speaker on DietPi using BlueALSA as an A2DP device for Mopidy , but I’m running into connection issues. I would appreciate any guidance.
What I’ve done so far:
Installed BlueALSA:
which bluealsa
/usr/bin/bluealsa
Started BlueALSA:
sudo bluealsa -p a2dp-sink
BlueALSA starts and logs:
Acquired D-Bus service name: org.bluealsa
Registering media application: /org/bluez/hci0
Exporting media endpoint object: /org/bluez/hci0/A2DP/SBC/sink/1
Prepared the speaker in pairing mode
Tried connecting the speaker via bluetoothctl:
bluetoothctl
power on
agent on
default-agent
scan on
trust xx:C6:xx:66:xx:99
connect xx:xx:xx:66:xx:99
Failed to connect: org.bluez.Error.Failed br-connection-profile-unavailable
Tried testing audio via ALSA:
aplay -D BOSE /usr/share/sounds/alsa/Front_Center.wav
Couldn't get BlueALSA PCM: PCM not found
BlueALSA virtual PCMs are not listed yet (bluealsa-aplay -L shows nothing)
System:
DietPi (latest version) on Raspberry Pi
Mopidy installed
BlueZ + BlueALSA Utilities installed
Problem / Question:
The BOSE speaker does not connect properly; the A2DP profiles are unavailable even though BlueALSA is running.
How can I get the speaker to connect correctly so BlueALSA creates the PCM and I can use it in Mopidy?
Are there any special considerations for DietPi / headless setups for Bluetooth A2DP?
Thanks in advance for your help!
Jappe
January 26, 2026, 8:09pm
2
I guess you missed to pair it first, here is what I did (I tested it on a RPI3B with my Nothing Ear headphones)
Activated bluetooth and ALSA via dietpi-config
Installed bluez-alsa-utils via apt
killed the already running process and did bluealsa --profile=a2dp-sink --codec=sbc to verify it’s working
Then I checked the systemd service, it was not running (systemctl status bluealsa )
activated and started it
systemctl enable bluealsa
systemctl start bluealsa
started bluetoothctl and did:
bluetoothctl
power on
agent on
default-agent
scan on
pair 2C:BE:EB:73:CC:A0
trust 2C:BE:EB:73:CC:A0
connect 2C:BE:EB:73:CC:A0
Then I verfied:
[Nothing Ear]> info 2C:BE:EB:73:CC:A0
Device 2C:BE:EB:73:CC:A0 (public)
Alias: Nothing Ear
Class: 0x00240404 (2360324)
Icon: audio-headset
Paired: yes
Bonded: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: SDP (00000001-0000-1000-8000-00805f9b34fb)
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Cont.. (0000110f-0000-1000-8000-00805f9b34fb)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: Generic Audio (00001203-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (66666666-6666-6666-6666-666666666666)
UUID: Vendor specific (aeac4a03-dff5-498f-843a-34487cf133eb)
UUID: Vendor specific (df21fe2c-2515-4fdb-8886-f12c4d67927c)
Modalias: bluetooth:v02B0p0000d001F
also with aplay:
bluealsa-aplay -L
bluealsa:DEV=2C:BE:EB:73:CC:A0,PROFILE=a2dp,SRV=org.bluealsa
Nothing Ear, trusted audio-headset, playback
A2DP (SBC): S16_LE 2 channels 48000 Hz
and then just a simple audio test:
root@TestPi3B:~# aplay -D bluealsa:DEV=2C:BE:EB:73:CC:A0,PROFILE=a2dp /usr/share/sounds/alsa/Front_Center.wav
[985] D: bluealsa-pcm.c:1538: Getting BlueALSA PCM: PLAYBACK 2C:BE:EB:73:CC:A0 a2dp
[985] D: bluealsa-pcm.c:1296: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Setting constraints
Wiedergabe: WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Rate: 48000 Hz, mono
[985] D: bluealsa-pcm.c:566: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Initializing HW
[985] D: bluealsa-pcm.c:580: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Changing BlueALSA PCM configuration: 2 ch, 48000 Hz -> 1 ch, 48000 Hz
[985] D: bluealsa-pcm.c:631: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: FIFO buffer size: 2048 frames
[985] D: bluealsa-pcm.c:636: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Selected HW buffer: 4 periods x 12000 bytes == 48000 bytes
[985] D: bluealsa-pcm.c:667: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Initializing SW
[985] D: bluealsa-pcm.c:717: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Prepared
[985] D: bluealsa-pcm.c:392: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Starting
[989] D: bluealsa-pcm.c:235: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Starting IO loop: 8
[985] D: bluealsa-pcm.c:723: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Draining
[989] D: bluealsa-pcm.c:244: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Pausing IO thread
[989] D: bluealsa-pcm.c:258: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: IO thread resumed
[985] D: bluealsa-pcm.c:428: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Stopping
[989] D: bluealsa-pcm.c:171: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: IO thread cleanup
[985] D: bluealsa-pcm.c:646: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Freeing HW
[985] D: bluealsa-pcm.c:475: /org/bluealsa/hci0/dev_2C_BE_EB_73_CC_A0/a2dpsrc/sink: Closing
And I was hearing a nice voice in the headphones
Jappe
January 26, 2026, 8:19pm
3
I also installed mopidy, and to get sound via BT working I edited /etc/mopidy/mopidy.conf, added
[audio]
output = alsasink device=bluealsa:DEV=2C:BE:EB:73:CC:A0,PROFILE=a2dp
(replace the MAC address)
and restarted the service.
temp
January 26, 2026, 8:28pm
4
Jappe:
is this the right file content?
cat /etc/systemd/system/bluealsa.service
[Unit]
Description=BlueALSA Bluetooth ALSA Proxy
Requires=bluetooth.service
After=bluetooth.service
[Service]
Type=simple
User=root
ExecStart=/usr/bin/bluealsa -p a2dp-source -p a2dp-sink
Restart=on-failure
RestartSec=5s
[Install]
WantedBy=multi-user.target
Jappe
January 26, 2026, 8:34pm
5
Yes, the installation of mopidy will add some lines to the service file, but this is expected behaviour.
temp
January 26, 2026, 8:37pm
6
is this service necessary?
bluealsa-aplay
Jappe
January 26, 2026, 8:43pm
7
Not for mopidy. If I understand correctly it’s needed when you wanna send audio to the SBC.
Jappe
January 26, 2026, 8:49pm
8
Is it working now?
Was the solution to pair the devices first?
temp
January 27, 2026, 4:36am
9
Yes, to pair it…and between each command you need to wait until it’s finished.
Thanks a lot
