Hi, i am (still) using a NUC9i9QNX as my dietpi server and i realised this morning that i am unable to start my squeezelite. The error messages i get are:
Nov 09 11:38:38 OldMan squeezelite[2725383]: Failed to create secure directory (/nonexistent/.config/pulse): No such file or directory
Nov 09 11:38:38 OldMan squeezelite[2725383]: [11:38:38.584887] test_open:281 playback open error: No such device
Nov 09 11:38:38 OldMan squeezelite[2725383]: [11:38:38.584907] output_init_common:401 unable to open output device: sysdefault:CARD=Audio
I havent used it in a while so i cannot exactly say when the problem appeared the first time.
At least i havent changed anything on the system recently (apart from replacing a broken USB HDD 2 months ago).
I can tell that my USB soundcard is being found:
dietpi@OldMan:~$ sudo lsusb | grep Audio
Bus 001 Device 006: ID 12d1:0010 Huawei Technologies Co., Ltd. KT USB Audio
However Squeezelite seems to “not see” the device in question - showing only my Hauppauge TV Stick:
dietpi@OldMan:~$ sudo squeezelite -l
Output devices:
hw:CARD=Cx231xxAudio,DEV=0 - Cx231xx Audio, Conexant cx231xx Capture - Direct hardware device without any conversions
plughw:CARD=Cx231xxAudio,DEV=0 - Cx231xx Audio, Conexant cx231xx Capture - Hardware device with all software conversions
sysdefault:CARD=Cx231xxAudio - Cx231xx Audio, Conexant cx231xx Capture - Default Audio Device
dsnoop:CARD=Cx231xxAudio,DEV=0 - Cx231xx Audio, Conexant cx231xx Capture - Direct sample snooping device
usbstream:CARD=Cx231xxAudio - Cx231xx Audio - USB Stream Output
Can somebody please help me sorting things out? Thanks!
