There is an issue when we try to automount an external USB disk which has been formatted as “exFat” under by example “/media/dabou2” as defined within the file “/etc/fstab”.
UUID=6010-1484 /media/dabou2 exfat noatime,lazytime,rw,nofail,noauto,gid=1000,uid=1000,x-systemd.automount
When the machine boots, the volume is not mounted
root@DietPi:~# df -h
udev 1.8G 0 1.8G 0% /dev
tmpfs 380M 8.1M 372M 3% /run
/dev/mmcblk1p1 15G 774M 14G 6% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
tmpfs 1.9G 0 1.9G 0% /tmp
tmpfs 50M 8.0K 50M 1% /var/log
/dev/nvme0n1 916G 168G 702G 20% /media/dabou
Surprisingly, content exists under “/media/dabou2”. Why ? I don t know ![]()
root@DietPi:~# ls -la /media/dabou2
total 1156
drwxrwxrwx 1 dietpi dietpi 131072 Jan 1 1970 .
drwxr-xr-x 4 root root 4096 Jan 27 11:04 ..
drwxrwxrwx 1 dietpi dietpi 131072 Jan 21 08:00 Famille
drwxrwxrwx 1 dietpi dietpi 131072 Jan 26 13:28 .fseventsd
drwxrwxrwx 1 dietpi dietpi 131072 Jan 24 16:46 Movies
drwxrwxrwx 1 dietpi dietpi 131072 Jan 25 08:17 Music
-rwxrwxrwx 1 dietpi dietpi 187 Jan 25 17:05 README.txt
drwxrwxrwx 1 dietpi dietpi 131072 Jan 26 15:30 samba
drwxrwxrwx 1 dietpi dietpi 131072 Jan 26 12:09 .Spotlight-V100
drwxrwxrwx 1 dietpi dietpi 131072 Jan 26 13:28 .Trashes
Something else: I can mount it manually but Fuse reports the following warning messages
mount -v -t exfat /dev/sda2 /media/dabou2
FUSE exfat 1.3.0
WARN: volume was not unmounted cleanly.
fuse: mountpoint is not empty
fuse: if you are sure this is safe, use the 'nonempty' mount option
and mount cmd reports:
/dev/sda2 on /mnt/dabou-usb type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,x-systemd.automount)
The volume seems to be well mounted anyway. Really bizarre
df -h
/dev/sda2 1.9T 185G 1.7T 10% /media/dabou2
Do you know how we could fix that ?
Cheers
Charles
