I have some issue when installing openssh, here’s the log.
somehow there’s no ucf folder in /usr/bin, any solution pls?
APT install for: openssh-client
- Command: apt-get -y --allow-change-held-packages install openssh-client
- Exit code: 100
DietPi version: v8.11.2 (MichaIng/master) | HW_MODEL: 3 | HW_ARCH: 3 | DISTRO: 6
- Image creator: DietPi Core Team
- Pre-image: from scratch
- Error log: Reading package lists...
Building dependency tree...
Reading state information...
openssh-client is already the newest version (1:8.4p1-5+deb11u1).
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up openssh-server (1:8.4p1-5+deb11u1) ...^M
/usr/bin/ucf: 444: [: missing ]^M
grep: ]: No such file or directory^M
dpkg: error processing package openssh-server (--configure):^M
installed openssh-server package post-installation script subprocess returned error exit status 1^M
Errors were encountered while processing:^M
openssh-server^M
E: Sub-process /usr/bin/dpkg returned an error code (1)
thank you for reply, but ucf seems installed already
sudo apt install ucf
Reading package lists... Done
ucf is already the newest version (3.0043).
ucf set to manually installed.
Do you want to continue? [Y/n] Y
openssh-server
apt reinstall ucf
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 74.0 kB of archives.
Get:1 https://deb.debian.org/debian bullseye/main arm64 ucf all 3.0043 [74.0 kB]
Fetched 74.0 kB in 1s (123 kB/s)
(Reading database ... 48536 files and directories currently installed.)
Preparing to unpack .../archives/ucf_3.0043_all.deb ...
Unpacking ucf (3.0043) over (3.0043) ...
Setting up ucf (3.0043) ...
openssh-server
