Rpi4 rev 1.5 has improvements in power management not overheating too much
Python 3.11.1 uses like half of CPU and is a 25% faster
Can you please answer to these two questions?
Thanks in advance =)
we don’t make any difference between RPi4 models. 64bit image is compatible with all Raspberry Pi 3 and 4 models, as well as Raspberry Pi 2 PCB v1.2 and Zero 2.
Regarding Python, we install apt
package from global Debian repository. On Debian Bullseye, current version is 3.9.2. Even on Debian Bookworm it is 3.10.6 only Debian -- Package Search Results -- python3-dev
If you need a more recent Python version, have a look at pyenv: GitHub - pyenv/pyenv: Simple Python version management
thank you guys, I may update to python 3.11.1 manually (maybe someone post a tutorial for DietPi? lol) and as for the rev 1.5 I guess it will work fine on the go with Dietpi not needing to do any workaround on firmware/software
