Hiya,
I would like very much to use DietPi as a lightweight internet radio, headless.
mdp is running, starting with the playlist, on the volume last used, everything is fine and simple.
The IQaudio amp works smoothly.
But, sorry for that, I am struggling with adding my IR remote.
It is an Odroid one, which I am using with lircd.conf and lircrc on another distro.
There it works like a charm. This means both of these files are tested and good to go.
How and where can I drop these files or the content of them into DietPi?
Any help is appreciated.
I tried, but without any success. (SSH, nano, mv etc. etc.)
To activate the JustBoom remote via
dietpi-config // 1 Display Options // 11 Justboom IR remote
did not give me a proper hint to substitute the JB settings with mine.
Regards,
Urban
PS: I know, never change …
But the old distro does not work on RB 3, which I need for Wifi.
It is not a mindless change, it is evolution. Hopefully.
