gins/Geyser-Spigot.jar
[FAILED] DietPi-Software | Checking URL: https://ci.nukkitx.com/job/GeyserMC/job /Floodgate/job/development/lastStableBuild/artifact/bukkit/target/floodgate-bukk it.jar
- Command: curl -ILfvm 5 https://ci.nukkitx.com/job/GeyserMC/job/Floodgate/job/ development/lastStableBuild/artifact/bukkit/target/floodgate-bukkit.jar
[FAILED] DietPi-Software | Checking URL: https://ci.nukkitx.com/job/GeyserMC/job/Floodgate/job/development/lastStableBuild/artifact/bukkit/target/floodgate-bukkit.jar
- Command: curl -ILfvm 5 https://ci.nukkitx.com/job/GeyserMC/job/Floodgate/job/development/lastStableBuild/artifact/bukkit/target/floodgate-bukkit.jar
- DietPi has encountered an error -
- Please create a ticket: https://github.com/MichaIng/DietPi/issues -
- Copy and paste only the BLUE lines below into the ticket -
#### Details:
- Date | Sat Dec 12 00:07:30 CET 2020
- DietPi version | v6.34.0 (MichaIng/beta)
- Image creator | DietPi Core Team
- Pre-image | Raspbian Lite
- Hardware | RPi 3 Model B (armv7l) (ID=3)
- Kernel version | Linux DietPi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
- Distro | buster (ID=5,RASPBIAN=1)
- Command | curl -ILfvm 5 https://ci.nukkitx.com/job/GeyserMC/job/Floodgate/job/development/lastStableBuild/artifact/bukkit/target/floodgate-bukkit.jar
- Exit code | 22
- Software title | DietPi-Software
#### Steps to reproduce:
<!-- Explain how to reproduce the issue -->
1. ...
2. ...
#### Expected behaviour:
<!-- What SHOULD happen? -->
#### Actual behaviour:
<!-- What IS happening? -->
#### Extra details:
<!-- Please post any extra details that might help solve the issue -->
#### Additional logs:
Expire in 0 ms for 6 (transfer 0x5108a0)
Expire in 5000 ms for 8 (transfer 0x5108a0)
Expire in 1 ms for 1 (transfer 0x5108a0)
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0* Expire in 0 ms for 1 (transfer 0x5108a0)
Expire in 2 ms for 1 (transfer 0x5108a0)
Expire in 3 ms for 1 (transfer 0x5108a0)
Expire in 4 ms for 1 (transfer 0x5108a0)
Expire in 5 ms for 1 (transfer 0x5108a0)
Trying 2606:4700:3034::681b:8c52…
TCP_NODELAY set
Expire in 2491 ms for 3 (transfer 0x5108a0)
Expire in 200 ms for 4 (transfer 0x5108a0)
Connected to ci.nukkitx.com (2606:4700:3034::681b:8c52) port 443 (#0)
Connection #0 to host ci.nukkitx.com left intact
curl: (22) The requested URL returned error: 404
[FAILED] DietPi-Software | Unable to continue, DietPi-Software will now terminate.
It’s not your fault. Looks like an issue at the 3rd party side for Geyser and Floodgate plugins. There are not able to download atm. Maybe a server issue.
If you are confront with the error, you could adjust the command on the error handle screen. It might be possible to scroll down on the available commands. Just select Change command and change from
An additional installation problem as it was finishing:
┌─────────────────────────────┤ DietPi-Software ├──────────────────────────────┐
│ [FAILED] File does not exist or cannot be written to by current user │
│ Please verify the existence of the file $3 │
│ /mnt/dietpi_userdata/papermc/server.properties │
│ Retry with proper permissions or apply the setting manually: │
│ enable-rcon=true │
│ <Ok>
I ran into both of these errors too, the download error as well as the server.properties file error. Both suggested fixes worked for me. Editing the download URL fixed the first issue (and it did have to be done twice) as well as running the reinstall command fixed the file error. Thanks!
