Try it with just one drive connector and having it set to rw.
Ok, let’s see if I’ve understood it correctly, the command I should execute in dietpi is : ntfsfix
I would like it to be very clear to me before performing all the tests, I will try to back up data as soon as possible and first test on windows if it works correctly and if so, I will test on dietpi by launching the command
In the first answer of the linked thread is an example how to execute the command.
It worked wonderfully, first I was scared because I did a test and everything was ok, then I did it on productive HDDs and plex told me that the files did not exist, I was a little scared and I almost suffered a micro heart attack, but then everything went back to normal, everyone the files ok, thank you very much!
