the problem is not updating it, the main problem is that it needs a manual interaction every x days (30 days, I guess) to function.
that is really unnecessary and was not the case in No-IP’s earlier days.
this was not a feedback on your post naddel81 as you can see on the quote
I found that just yesterday as well. Already implemented. If the noip2 client is found on the system, it suggests to remove it in favour of the new Cron+cURL-based setup. The dedicated No-IP software install option is removed. I’ll open a PR tomorrow.
PR up and ready for testing: https://github.com/MichaIng/DietPi/pull/4229
are there plans to implement the curl method into the GUI?
This is possible with Hetzner for example:
Update Zone
curl -X "PUT" "https://dns.hetzner.com/api/v1/zones/{ZoneID}" \
-H 'Content-Type: application/json' \
-H 'Auth-API-Token: LlGoDUQ39S6akqoav5meAsv5OIpeywhj' \
-d $'{
"name": "example.com",
"ttl": 86400
Did you try our custom section within dietpi-ddns?
yes but I was not successful.
I used the URL with my Zone ID
As user I put in the string for “no user”.
Password: my api access token
I always get 401 error.
Whats wrong here?
Thanks
Hyper
Both, user and password should be empty \"0\"
The whole URL should be one single line, containing your API-Token
ok, but how do I integrate the Api token into the URL?
Or do I just put in the Curl command in here, because that did not work. :-/
Ask your DDNS provider what the URL must look like in a single line.
I could not find it but ChatGPT helped me with the syntax ![]()
https://dns.hetzner.com/api/v1/zones/[ZoneID]?Auth-API-Token=[TOKEN]
EDIT:
Update klappt aber leider nicht, irgendwas ist dennoch falsch.
