Immich external library help
  • G_DIETPI_VERSION_CORE=10
  • G_DIETPI_VERSION_SUB=4
  • G_DIETPI_VERSION_RC=2
  • G_GITBRANCH=‘master’
  • G_GITOWNER=‘MichaIng’
  • trixie
  • Linux DietPi 6.12.90+deb13.1-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.90-2 (2026-05-27) x86_64 GNU/Linux
  • amd64
  • SBC model | echo $G_HW_MODEL_NAME
  • Native PC (x86_64)
  • Power supply used | Computer power brick
  • Software title | Immich native
  • From dietpi-software
    have not tried
  1. Install Immich from software store
  2. create account through the web interface
  3. Go to Settings → External storage
  • It should scan the files and add them
  • Despite trying multiple times to add the path is always comes up as “invalid”. I have tried re-installing several times over the last few months, and changing the read/write permissions of the actual folders
You would need to share the path you try to add
We do apply strict sandboxing to the systemd unit, which implies that it does not have any access to /home and /root, has a private /tmp and /var/tmp, and no write access to anywhere outside of /mnt.
If that is the issue: Generally, do not grant system services access to home dirs, and neither to world-writable dirs like /tmp. The prior counter-acts a common security/privacy convention, the latter is vulnerable to malicious symlinks and similar. But if you must, you can override/extend systemd directives the unit, either via dietpi-config or manually creating an override config in /etc/systemd/system/immich.service.d, adding ReadWritePaths=/my/storage.
Thank you. That last option fixed the problem.
