Can You tell me how to get rid of that unused processes like Cloudflare I see there?
The output:
dietpi@DietPi:~$ ls -lah /tmp
razem 1,1M
drwxrwxrwt 13 root root 520 11-28 23:13 .
drwxr-xr-x 24 root root 4,0K 11-19 23:58 ..
prwx------ 1 emby dietpi 0 11-28 13:46 clr-debug-pipe-1375135-7826008-inprwx------ 1 emby dietpi 0 11-28 13:46 clr-debug-pipe-1375135-7826008-out
prwx------ 1 ombi nogroup 0 11-27 16:02 clr-debug-pipe-736-1115-in
prwx------ 1 ombi nogroup 0 11-27 16:02 clr-debug-pipe-736-1115-out
-rw-r--r-- 1 dietpi dietpi 689 11-28 14:04 crontab
drwxrwxrwx 3 emby dietpi 60 11-27 16:02 .dotnet
srw------- 1 emby dietpi 0 11-28 13:46 dotnet-diagnostic-1375135-7826008-socket
srw------- 1 ombi nogroup 0 11-27 16:02 dotnet-diagnostic-736-1115-socketdrwxrwxrwt 2 root root 40 11-27 16:02 .font-unix
drwxrwxrwt 2 root root 40 11-27 16:02 .ICE-unix
-rw-r--r-- 1 dietpi dietpi 245 11-28 14:04 jDaEBluImq6Ux04T.stderr
-rw-r--r-- 1 dietpi dietpi 1,1M 11-28 14:05 jDaEBluImq6Ux04T.stdout
drwx------ 3 root root 60 11-28 13:46 systemd-private-1a58c2e03c394821959839c3d393e4e3-bazarr.service-JtIz0e
drwx------ 3 root root 60 11-27 16:02 systemd-private-1a58c2e03c394821959839c3d393e4e3-haveged.service-S6OTHg
drwx------ 3 root root 60 11-28 13:46 systemd-private-1a58c2e03c394821959839c3d393e4e3-redis-server.service-7HY5rj
drwx------ 3 root root 60 11-27 16:02 systemd-private-1a58c2e03c394821959839c3d393e4e3-systemd-logind.service-a2lezi
drwxrwxrwt 2 root root 40 11-27 16:02 .Test-unix
-rw------- 1 dietpi dietpi 16 11-27 23:51 tmp.6aywuabdYZ
-rw------- 1 dietpi dietpi 16 11-28 00:21 tmp.9LwUfibGm2
drwxr-xr-x 3 www-data www-data 60 11-27 16:02 www-data-temp-aspnet-0
drwxrwxrwt 2 root root 40 11-27 16:02 .X11-unix
drwxrwxrwt 2 root root 40 11-27 16:02 .XIM-unix
-rw-r--r-- 1 root root 178 11-28 22:03 XpKVF4WGqgj3D1N0.stderr
-rw-r--r-- 1 root root 0 11-28 22:03 XpKVF4WGqgj3D1N0.stdout
dietpi@DietPi:~$
can you reboot your system and share following
ls -la /tmp
ps -ef | grep crontab-ui
dietpi@DietPi:~$ ls -la /tmp
razem 4
drwxrwxrwt 13 root root 380 11-29 07:23 .
drwxr-xr-x 24 root root 4096 11-19 23:58 ..
prwx------ 1 emby dietpi 0 11-29 07:10 clr-debug-pipe-1076-1941-in
prwx------ 1 emby dietpi 0 11-29 07:10 clr-debug-pipe-1076-1941-out
prwx------ 1 ombi nogroup 0 11-29 07:10 clr-debug-pipe-739-1147-in
prwx------ 1 ombi nogroup 0 11-29 07:10 clr-debug-pipe-739-1147-out
drwxrwxrwx 3 emby dietpi 60 11-29 07:10 .dotnet
srw------- 1 emby dietpi 0 11-29 07:10 dotnet-diagnostic-1076-1941-socket
srw------- 1 ombi nogroup 0 11-29 07:10 dotnet-diagnostic-739-1147-socket
drwxrwxrwt 2 root root 40 11-29 07:10 .font-unix
drwxrwxrwt 2 root root 40 11-29 07:10 .ICE-unix
drwx------ 3 root root 60 11-29 07:10 systemd-private-27f237672ff44df994077b47b681b0ea-bazarr.service-Wf3iGi
drwx------ 3 root root 60 11-29 07:10 systemd-private-27f237672ff44df994077b47b681b0ea-haveged.service-NzMYxh
drwx------ 3 root root 60 11-29 07:10 systemd-private-27f237672ff44df994077b47b681b0ea-redis-server.service-HVt8jh
drwx------ 3 root root 60 11-29 07:10 systemd-private-27f237672ff44df994077b47b681b0ea-systemd-logind.service-sMqNMh
drwxrwxrwt 2 root root 40 11-29 07:10 .Test-unix
drwxr-xr-x 3 www-data www-data 60 11-29 07:10 www-data-temp-aspnet-0
drwxrwxrwt 2 root root 40 11-29 07:10 .X11-unix
drwxrwxrwt 2 root root 40 11-29 07:10 .XIM-unix
dietpi@DietPi:~$ ps -ef | grep crontab-ui
root 733 1 0 07:10 ? 00:00:00 node /usr/local/bin/crontab-ui
dietpi 22770 21892 0 07:24 pts/0 00:00:00 grep crontab-ui
Hi, today after reboot it works. I can save to crontab from webUI.
Do You know why that command don’t work when I want to backup my other device from crontab-ui?
rsync -avz --exclude=.cache dietpi@192.168.0.111:/home/dietpi /mnt/Toshiba/Backup/dietpi-laptop/home
I exchange ssh keys and can login without password between that two devices.
trendy
29 November 2022 10:06
25
Cronjob runs as root, not as dietpi.
The other thing is to use full paths for the commands.
OK, but do You know why that command works with termial and when I Run it from crontab-ui I have errors:
Tue Nov 29 11:32:17 CET 2022
Host key verification failed.
rsync: connection unexpectedly closed (0 bytes received so far) [Receiver]
rsync error: unexplained error (code 255) at io.c(228) [Receiver=3.2.3]
on system:
dietpi@DietPi:~$ sudo systemctl status crontab-ui.service
● crontab-ui.service - Crontab UI
Loaded: loaded (/etc/systemd/system/crontab-ui.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-11-29 07:10:40 CET; 4h 23min ago
Main PID: 733 (node)
Tasks: 11 (limit: 9352)
Memory: 79.6M
CPU: 2.396s
CGroup: /system.slice/crontab-ui.service
└─733 node /usr/local/bin/crontab-ui
lis 29 10:35:09 DietPi crontab-ui[733]: env vars
lis 29 10:35:09 DietPi crontab-ui[733]: Running job
lis 29 10:35:09 DietPi crontab-ui[733]: ID: XpKVF4WGqgj3D1N0
lis 29 10:35:09 DietPi crontab-ui[733]: Original command: rsync -avz --exclude=.cache dietpi@192.168.0.111:/home/dietpi /mnt/Toshiba/Backup/dietpi-laptop/home
lis 29 10:35:09 DietPi crontab-ui[733]: Executed command: ((({ rsync -avz --exclude=.cache dietpi@192.168.0.111:/home/dietpi /mnt/Toshiba/Backup/dietpi-laptop/home; } | tee /tmp/XpKVF4WGqgj3D1N0.stdout) 3>&1 1>&2 2>&3 | tee /tmp/XpKVF4WGqgj3D1N0.stderr) 3>&1 1>&2 2>&3); if test -f /tmp/XpKVF4WGqgj3D1N0.stderr; then date >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.log"; cat /tmp/XpKVF4WGqgj3D1N0.stderr >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.log"; fi; if test -f /tmp/XpKVF4WGqgj3D1N0.stdout; then date >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.stdout.log"; cat /tmp/XpKVF4WGqgj3D1N0.stdout >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.stdout.log"; fi
lis 29 11:32:17 DietPi crontab-ui[733]: env vars
lis 29 11:32:17 DietPi crontab-ui[733]: Running job
lis 29 11:32:17 DietPi crontab-ui[733]: ID: XpKVF4WGqgj3D1N0
lis 29 11:32:17 DietPi crontab-ui[733]: Original command: rsync -avz --exclude=.cache dietpi@192.168.0.111:/home/dietpi /mnt/Toshiba/Backup/dietpi-laptop/home
lis 29 11:32:17 DietPi crontab-ui[733]: Executed command: ((({ rsync -avz --exclude=.cache dietpi@192.168.0.111:/home/dietpi /mnt/Toshiba/Backup/dietpi-laptop/home; } | tee /tmp/XpKVF4WGqgj3D1N0.stdout) 3>&1 1>&2 2>&3 | tee /tmp/XpKVF4WGqgj3D1N0.stderr) 3>&1 1>&2 2>&3); if test -f /tmp/XpKVF4WGqgj3D1N0.stderr; then date >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.log"; cat /tmp/XpKVF4WGqgj3D1N0.stderr >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.log"; fi; if test -f /tmp/XpKVF4WGqgj3D1N0.stdout; then date >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.stdout.log"; cat /tmp/XpKVF4WGqgj3D1N0.stdout >> "/usr/local/lib/node_modules/crontab-ui/crontabs/logs/XpKVF4WGqgj3D1N0.stdout.log"; fi
there seems to be a log file. Simply have a look.
I show log above. That is the same:
Mon Nov 28 21:11:05 CET 2022
Mon Nov 28 21:12:55 CET 2022
Mon Nov 28 21:55:56 CET 2022
Mon Nov 28 22:03:01 CET 2022
Tue Nov 29 10:35:09 CET 2022
trendy
29 November 2022 10:43
29
Your command is using relative paths, use absolute ones.
Also run as user root the command ssh dietpi@192.168.0.111 to verify the host key.
Do I need to make file /etc/rsync.conf like in this tutorial:
I can rsync with that command from termial without any problem.
Meybe I will add bug report on github on crontab-ui.
the host key verification failed
Can I do something with that?
Jappe
29 November 2022 11:53
34
This error is caused most likely by old/changed keys.
Here is some more info:
https://bobcares.com/blog/rsync-host-key-verification-failed/
I have some ssh keys before when install cookpit and it make such keys but yesterday I checked and connection with keys don’t work so I make new keys and now it works ok.
systemd units run as root user, unless you define the user explicitly. For editing crontab, it is also required, or does it edit the user crontab only?
However when running your rsync, assure that the root user has the matching public SSH key in /root/.ssh/authorized_keys. Since you login at the remote as dietpi user, I guess also on the local host the dietpi user has the key accepted, but root not yet.
You do not need rsyncd daemon running. That would be for a different transport protocol, while SSH is used by default.
So I need to make ssh-keys as root?
yes, you need to configure ssh key access for user root. Keys configured for user dietpi will not be used.
OK, I don’t change root in crontab-ui command. Now it works great.
Thanks for Your help nad patience
Regards.
