DietPi version |
cat /boot/dietpi/.version-
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=7
G_DIETPI_VERSION_RC=1
G_GITOWNER=‘MichaIng’ -
Distro version |
bookworm -
Kernel version |
uname --all
Linux DietPi 6.1.0-25-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.106-3 (2024-08-26) x86_64 GNU/Linux -
Architecture |
dpkg --print-architecture
amd64 -
SBC model |
Native PC (x86_64) -
5V 2A -
none
Good day everyone,
I’m trying to setup Hotspot on Wyse 3040 with Marvell (AW-CM389MA) wifi m.2 card. All drivers are installed already. Wifi card seems to be working. Hostapd and dhcpd installed and configured.
The problem is that I can’t connect to the created wifi network. I tried many devices without success. Help me please.
root@DietPi:~$ cat /etc/network/interfaces
# Drop-in configs
source interfaces.d/*
auto lo eth0 mlan0
iface lo inet loopback
# Ethernet
allow-hotplug eth0
iface eth0 inet dhcp
address 192.168.0.100
netmask 255.255.255.0
gateway 192.168.0.1
#dns-nameservers 192.168.2.1
# WiFi
# allow-hotplug mlan0
iface mlan0 inet static
address 192.168.42.1
#gateway 192.168.42.1
#dns-nameservers 9.9.9.9 149.112.112.112
# iptables NAT rules
up iptables-restore < /etc/iptables.ipv4.nat
up ip6tables-restore < /etc/iptables.ipv6.nat
root@DietPi:~$ cat /etc/hostapd/hostapd.conf
interface=mlan0
#bridge=br0
driver=nl80211
ssid=Wyse3040
country_code=US
hw_mode=g
channel=3
#ieee80211n=0
#ieee80211ac=0
#ieee80211ax=0
#wmm_enabled=0
macaddr_acl=0
auth_algs=1
#ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=12345678
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
root@DietPi:~$ cat /etc/dhcp/dhcpd.conf
authoritative;
#default-lease-time 43200;
#max-lease-time 86400;
subnet 192.168.42.0 netmask 255.255.255.0 {
range 192.168.42.10 192.168.42.250;
option broadcast-address 192.168.42.255;
option routers 192.168.42.1;
option domain-name "local";
option domain-name-servers 9.9.9.9, 149.112.112.112;
root@DietPi:~$ systemctl status isc-dhcp-server.service
● isc-dhcp-server.service - LSB: DHCP server
Loaded: loaded (/etc/init.d/isc-dhcp-server; generated)
Active: active (running) since Mon 2024-09-30 14:02:21 BST; 15min ago
Docs: man:systemd-sysv-generator(8)
Process: 706 ExecStart=/etc/init.d/isc-dhcp-server start (code=exited, status=0/SUCCESS)
Tasks: 1 (limit: 2199)
Memory: 6.5M
CPU: 160ms
CGroup: /system.slice/isc-dhcp-server.service
└─718 /usr/sbin/dhcpd -4 -q -cf /etc/dhcp/dhcpd.conf mlan0
Sep 30 14:02:19 DietPi systemd[1]: Starting isc-dhcp-server.service - LSB: DHCP server...
Sep 30 14:02:19 DietPi isc-dhcp-server[706]: Launching IPv4 server only.
Sep 30 14:02:19 DietPi dhcpd[718]: Wrote 0 leases to leases file.
Sep 30 14:02:19 DietPi dhcpd[718]: Server starting service.
Sep 30 14:02:21 DietPi isc-dhcp-server[706]: Starting ISC DHCPv4 server: dhcpd.
Sep 30 14:02:21 DietPi systemd[1]: Started isc-dhcp-server.service - LSB: DHCP server.
root@DietPi:~$ systemctl status hostapd.service
● hostapd.service - Access point and authentication server for Wi-Fi and Ethernet
Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; preset: enabled)
Active: active (running) since Mon 2024-09-30 14:02:19 BST; 16min ago
Docs: man:hostapd(8)
Process: 691 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=0/SUCCESS)
Main PID: 696 (hostapd)
Memory: 4.9M
CPU: 130ms
CGroup: /system.slice/hostapd.service
└─696 /usr/sbin/hostapd -B -P /run/hostapd.pid /etc/hostapd/hostapd.conf
Sep 30 14:02:19 DietPi systemd[1]: Starting hostapd.service - Access point and authentication server for Wi-Fi and Ethernet...
Sep 30 14:02:19 DietPi hostapd[691]: nl80211: kernel reports: Registration to specific type not supported
Sep 30 14:02:19 DietPi hostapd[691]: mlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sep 30 14:02:19 DietPi systemd[1]: Started hostapd.service - Access point and authentication server for Wi-Fi and Ethernet.
Sep 30 14:04:27 DietPi hostapd[696]: mlan0: STA 46:eb:28:97:ec:89 IEEE 802.11: associated
Sep 30 14:04:28 DietPi hostapd[696]: mlan0: STA 46:eb:28:97:ec:89 RADIUS: starting accounting session E36C387086830E7E
Sep 30 14:04:28 DietPi hostapd[696]: mlan0: STA 46:eb:28:97:ec:89 WPA: pairwise key handshake completed (RSN)
Sep 30 14:04:46 DietPi hostapd[696]: mlan0: STA 46:eb:28:97:ec:89 IEEE 802.11: disassociated
