HomeKit Devices not showing up in Home Assistant
I’ve just installed a fresh instance of Home Assistant through dietpi-software, and trying to connect Mysa thermostats via Homekit.
I’ve followed every guide online I could find, which all basically say you use the Mysa app to connect the thermostat to your wifi network, then it will show up in Home Assistant under ‘Integrations’. However for me nothing is showing up.
I cannot check the network configuration within HA, as it shows “External access disabled”.
One person notes “In HA, if Homekit did not find it already, add a Homekit controller integration” however following this guide, I seem to have the prerequisites in place for HK Integration already set in the configuration.yaml.
I am showing the following error under notifications
" Invalid config
The following integrations and platforms could not be set up:
  • recorder
  • history
  • logbook
  • energy
  • default_config
I’m at a loss here, does anyone know what the issue may be?
I noticed this is a non-supervisor install, perhaps it’s missing HK integration somehow? Or it’s linked to the issue of network settings not being accessible? Or the error log above?
Looking for the simplest option to get these thermostats paired, thx!
Maybe you’ll have more luck to ask in a dedicated HA forum/group, rather than in dietpi forum. I hope someone else who is using HA will have some idea to help.
