HomeBridge and vcgencmd issue
Yes, I have searched the existing open and closed issues
  • G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=14
    G_DIETPI_VERSION_RC=2
  • Distro version | bookworm 0
  • Kernel version | Linux DietPi 6.12.34+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.34-1+rpt1~bookworm (2025-06-26) aarch64 GNU/Linux
  • Architecture | arm64
  • SBC model | RPi 4 Model B (aarch64)
  • SD card used | USB adapter w/ Samsung Pro Plus 128GB microsd
  • Software title | HomeBridge w/ Unifi Protect Plugin
  • Was the software title installed freshly or updated/migrated? Updated but issue has always been there
  • Can this issue be replicated on a fresh installation of DietPi? yes
  1. Install Unifi Protect Plugin for HomeBridge on rpm
  2. Observe logs
  • no error would happen and hardware encoding should work
  • defaulting to software encoding
Log:
[7/25/2025, 11:27:17 PM] [UniFi Protect] Error running vcgencmd: Command failed: vcgencmd get_mem gpu
[7/25/2025, 11:27:17 PM] [UniFi Protect] Unable to probe the capabilities of your Homebridge host without access to 'vcgencmd'. Ensure that it is available in your path and correctly working.
I suspect that home bridge doesn’t have the required privileges to probe vcgencmd as the command also fails for my user account but works fine under sudo. Without hardware encoding the video stream is much slower to start and obviously uses more CPU resources.
Did you tried adding the user into video group?
I am embarrassed to admit but im unsure how to do that. Is Homebridge using its own user named “homebridge” and if so would it just be sudo usermod -a -G video homebridge ?
yes, the command added homebridge to the video group but I’m still getting the same error :frowning:
maybe @MichaIng has an idea
Please do this:
cat << '_EOF_' > /lib/udev/rules.d/10-vc.rules
KERNEL=="vcio", GROUP="video", MODE="0660"
KERNEL=="vchiq", GROUP="video", MODE="0660"
SUBSYSTEM=="vc-sm", GROUP="video", MODE="0660"
KERNEL=="vcsm-cma", GROUP="video", MODE="0660"
_EOF_
chgrp video /dev/vcio
chmod 0660 /dev/vcio
We need to update our raspberrypi-sys-mods package :thinking:.
Ok so doing what you said plus adding “homebridge” to the video group did the trick! Thank you.
For those who stumble across this issue, run the commands in terminal that @MichaIng shared
_EOF_
and then do
Thanks for the udev rule, that fixed it for me and Octoprint.
I had manually changed perms on /dev/vcio but it didn’t survive a reboot…
Only difference from solution above is changing homebridge to octoprint on the usermod command.
Thanks again!
