I’ve installed Home Assistant via dietpi-software and it ran fine, but does not auto start on boot. Attempting to start it manually fails and returns the following errors:
root@hass:~# sudo su -s /bin/bash homeassistant
bash: warning: setlocale: LC_ALL: cannot change locale (0.UTF-8)
homeassistant@hass:/root$ cd /srv/homeassistant
homeassistant@hass:/srv/homeassistant$ source bin/activate
(homeassistant) homeassistant@hass:/srv/homeassistant$ hass
Config directory: /home/homeassistant/.homeassistant
2017-09-07 20:14:16 ERROR (Thread-2) [homeassistant.util.yaml] while parsing a block mapping
in "/home/homeassistant/.homeassistant/configuration.yaml", line 1, column 1
expected <block end>, but found '<block mapping start>'
in "/home/homeassistant/.homeassistant/configuration.yaml", line 72, column 2
2017-09-07 20:14:16 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block mapping
^CException ignored in: <module 'threading' from '/usr/lib/python3.4/threading.py'>
File "/usr/lib/python3.4/threading.py", line 1294, in _shutdown
t.join()
File "/usr/lib/python3.4/threading.py", line 1060, in join
self._wait_for_tstate_lock()
File "/usr/lib/python3.4/threading.py", line 1076, in _wait_for_tstate_lock
elif lock.acquire(block, timeout):
KeyboardInterrupt
Thanks for any assistance.
