Home Assistant no longer starts after DietPi + Home Assistant update (exec: hass: not found)
  • DietPi version
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=13
G_DIETPI_VERSION_RC=2
G_GITBRANCH='master'
G_GITOWNER='MichaIng'
G_LIVE_PATCH_STATUS[0]='not applicable'
G_LIVE_PATCH_STATUS[1]='applied'
G_LIVE_PATCH_STATUS[2]='not applicable'
G_LIVE_PATCH_STATUS[3]='applied'
  • Distro version
bookworm 0
  • Kernel version
6.12.25+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30) aarch64 GNU/Linux
  • Architecture
arm64
  • SBC model |
    RPi 5 Model B (aarch64)
  • Power supply used |
Official Raspberry Pi 5 power supply
  • SD card used |
128GB SSD
  • Software title | Home Assistant
  • Was the software title installed freshly or updated/migrated? β†’ Yes
  1. Update DietPi to version 9.13.2
  2. Update Home Assistant via dietpi-software reinstall 157
  • Home Assistant starts regularly
Home-Assistant service shows:
Γ— home-assistant.service - Home Assistant (DietPi)
     Loaded: loaded (/etc/systemd/system/home-assistant.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Sun 2025-06-08 19:13:04 CEST; 6min ago
   Duration: 421ms
    Process: 7812 ExecStart=/home/homeassistant/homeassistant-start.sh (code=exited, status=127)
   Main PID: 7812 (code=exited, status=127)
        CPU: 158ms
giu 08 19:13:04 hostname systemd[1]: Started home-assistant.service - Home Assistant (DietPi).
giu 08 19:13:04 hostname Home Assistant[7812]: /home/homeassistant/homeassistant-start.sh: 3: exec: hass: not found
giu 08 19:13:04 hostname systemd[1]: home-assistant.service: Main process exited, code=exited, status=127/n/a
giu 08 19:13:04 hostname systemd[1]: home-assistant.service: Failed with result 'exit-code'.
After updating my existing installation, Home Assistant no longer starts.
All files related to Home Assistant appear to still be in their correction location, including hass.
My hypothesis is the problem is due to the /home/homeassistant/.local/bin no longer being on $PATH, as it seems as if the dietpi launch script cannot find the file anymore.
I have tried adding it to $PATH and rebooting multiple times with no success. Same error appears when restarting the service.
For all users, including root and homeassistant, echo $PATH now shows:
/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/home/homeassistant/.local/bin
Any thoughts as to how I could resolve this?
Keep in mind home assistant has an own user with own path and pyenv environment.
Best trying to reinstall again
Thank you for the reply.
I’ve already tried that two times. I’ve also tried adding the $PATH /home/homeassistant/.local/bin folder for the homeassistant user. The problem keeps occurring.
I’ve tried that one more time, including restarting the service for the python module building. Same result: /home/homeassistant/homeassistant-start.sh: 3: exec: hass: not found Here’s the log from the installation, in case it’s useful:
 DietPi-Software
 Step: Installing Home Assistant: Open source home automation platform
[ INFO ] DietPi-Software | Home Assistant user:  homeassistant
[ INFO ] DietPi-Software | Home Assistant home:  /home/homeassistant
[ INFO ] DietPi-Software | pyenv activation:     ". /home/homeassistant/pyenv-activate.sh"
[ INFO ] DietPi-Software | pyenv Python version: 3.13.3
[  OK  ] DietPi-Software | usermod -aG dialout,gpio,i2c -d /home/homeassistant -s /usr/sbin/nologin homeassistant
[  OK  ] DietPi-Software | mkdir -p /home/homeassistant
[  OK  ] DietPi-Software | chown homeassistant:homeassistant /home/homeassistant
[  OK  ] DietPi-Software | cd /tmp/DietPi-Software
[  OK  ] DietPi-Software | Checking URL: https://github.com/pyenv/pyenv/archive/master.tar.gz
[ INFO ] DietPi-Software | G_THREAD_START_0 | curl -sSfL https://github.com/pyenv/pyenv/archive/master.tar.gz -o master.tar.gz
[ INFO ] DietPi-Software | APT install g++ make libssl-dev zlib1g-dev libbz2-dev libreadline-dev libsqlite3-dev liblzma-dev libffi-dev, please wait...
Reading package lists...
Building dependency tree...
Reading state information...
g++ is already the newest version (4:12.2.0-3).
make is already the newest version (4.3-4.1).
libssl-dev is already the newest version (3.0.16-1~deb12u1+rpt1).
zlib1g-dev is already the newest version (1:1.2.13.dfsg-1+rpt1).
libbz2-dev is already the newest version (1.0.8-5+b1).
libreadline-dev is already the newest version (8.2-1.3).
libsqlite3-dev is already the newest version (3.40.1-2+deb12u1).
liblzma-dev is already the newest version (5.4.1-1).
libffi-dev is already the newest version (3.4.4-1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
[  OK  ] DietPi-Software | APT install g++ make libssl-dev zlib1g-dev libbz2-dev libreadline-dev libsqlite3-dev liblzma-dev libffi-dev
[  OK  ] DietPi-Software | G_THREAD: All threads finished
[  OK  ] DietPi-Software | tar xf master.tar.gz
[  OK  ] DietPi-Software | rm master.tar.gz
[  OK  ] DietPi-Software | chown -R homeassistant:homeassistant pyenv-master
[  OK  ] DietPi-Software | rm -R /home/homeassistant/.pyenv
[  OK  ] DietPi-Software | mv pyenv-master /home/homeassistant/.pyenv
[  OK  ] DietPi-Software | rm -R /home/homeassistant/.homeassistant
[  OK  ] DietPi-Software | ln -sf /mnt/dietpi_userdata/homeassistant /home/homeassistant/.homeassistant
[  OK  ] DietPi-Software | ln -sf /home/homeassistant/.pyenv/versions/3.13.3/lib/python3.13/site-packages /mnt/dietpi_userdata/homeassistant/deps
[  OK  ] DietPi-Software | mkdir -p /home/homeassistant/.pip
[  OK  ] DietPi-Software | eval echo -e '[global]\nno-cache-dir=true' > '/home/homeassistant/.pip/pip.conf'
[ INFO ] DietPi-Software | Compiling and installing Python 3.13.3 into pyenv, which will take a while ..., please wait...
Downloading Python-3.13.3.tar.gz...
-> https://www.python.org/ftp/python/3.13.3/Python-3.13.3.tgz
Installing Python-3.13.3...
Installed Python-3.13.3 to /home/homeassistant/.pyenv/versions/3.13.3
[  OK  ] DietPi-Software | Compiling and installing Python 3.13.3 into pyenv, which will take a while ...
[ INFO ] DietPi-Software | Set Python . /home/homeassistant/pyenv-activate.sh as global version for this pyenv instance, please wait...
[  OK  ] DietPi-Software | Set Python . /home/homeassistant/pyenv-activate.sh as global version for this pyenv instance
[ INFO ] DietPi-Software | Upgrading base modules: pip setuptools wheel, please wait...
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: pip in ./.local/lib/python3.11/site-packages (25.1.1)
Requirement already satisfied: setuptools in ./.local/lib/python3.11/site-packages (80.9.0)
Requirement already satisfied: wheel in ./.local/lib/python3.11/site-packages (0.45.1)
[  OK  ] DietPi-Software | Upgrading base modules: pip setuptools wheel
[ INFO ] DietPi-Software | Installing additional dependencies: isal , please wait...
Requirement already satisfied: isal in ./.local/lib/python3.11/site-packages (1.7.2)
[  OK  ] DietPi-Software | Installing additional dependencies: isal
[ INFO ] DietPi-Software | Installing Home Assistant core module, please wait...
Requirement already satisfied: homeassistant in ./.local/lib/python3.11/site-packages (2024.3.3)
Requirement already satisfied: aiohttp==3.9.3 in ./.local/lib/python3.11/site-packages (from homeassistant) (3.9.3)
Requirement already satisfied: aiohttp-cors==0.7.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.7.0)
Requirement already satisfied: aiohttp-fast-url-dispatcher==0.3.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.3.0)
Requirement already satisfied: aiohttp-zlib-ng==0.3.1 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.3.1)
Requirement already satisfied: astral==2.2 in ./.local/lib/python3.11/site-packages (from homeassistant) (2.2)
Requirement already satisfied: async-interrupt==1.1.1 in ./.local/lib/python3.11/site-packages (from homeassistant) (1.1.1)
Requirement already satisfied: attrs==23.2.0 in /usr/local/lib/python3.11/dist-packages (from homeassistant) (23.2.0)
Requirement already satisfied: atomicwrites-homeassistant==1.4.1 in ./.local/lib/python3.11/site-packages (from homeassistant) (1.4.1)
Requirement already satisfied: awesomeversion==24.2.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (24.2.0)
Requirement already satisfied: bcrypt==4.1.2 in ./.local/lib/python3.11/site-packages (from homeassistant) (4.1.2)
Requirement already satisfied: certifi>=2021.5.30 in /usr/lib/python3/dist-packages (from homeassistant) (2022.9.24)
Requirement already satisfied: ciso8601==2.3.1 in ./.local/lib/python3.11/site-packages (from homeassistant) (2.3.1)
Requirement already satisfied: hass-nabucasa==0.78.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.78.0)
Requirement already satisfied: httpx==0.27.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.27.0)
Requirement already satisfied: home-assistant-bluetooth==1.12.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (1.12.0)
Requirement already satisfied: ifaddr==0.2.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.2.0)
Requirement already satisfied: Jinja2==3.1.3 in ./.local/lib/python3.11/site-packages (from homeassistant) (3.1.3)
Requirement already satisfied: lru-dict==1.3.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (1.3.0)
Requirement already satisfied: PyJWT==2.8.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (2.8.0)
Requirement already satisfied: cryptography==42.0.5 in ./.local/lib/python3.11/site-packages (from homeassistant) (42.0.5)
Requirement already satisfied: pyOpenSSL==24.0.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (24.0.0)
Requirement already satisfied: orjson==3.9.15 in ./.local/lib/python3.11/site-packages (from homeassistant) (3.9.15)
Requirement already satisfied: packaging>=23.1 in /usr/local/lib/python3.11/dist-packages (from homeassistant) (24.0)
Requirement already satisfied: pip>=21.3.1 in ./.local/lib/python3.11/site-packages (from homeassistant) (25.1.1)
Requirement already satisfied: python-slugify==8.0.4 in ./.local/lib/python3.11/site-packages (from homeassistant) (8.0.4)
Requirement already satisfied: PyYAML==6.0.1 in ./.local/lib/python3.11/site-packages (from homeassistant) (6.0.1)
Requirement already satisfied: requests==2.31.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (2.31.0)
Requirement already satisfied: typing-extensions<5.0,>=4.10.0 in /usr/local/lib/python3.11/dist-packages (from homeassistant) (4.11.0)
Requirement already satisfied: ulid-transform==0.9.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.9.0)
Requirement already satisfied: urllib3<2,>=1.26.5 in /usr/lib/python3/dist-packages (from homeassistant) (1.26.12)
Requirement already satisfied: voluptuous==0.13.1 in ./.local/lib/python3.11/site-packages (from homeassistant) (0.13.1)
Requirement already satisfied: voluptuous-serialize==2.6.0 in ./.local/lib/python3.11/site-packages (from homeassistant) (2.6.0)
Requirement already satisfied: yarl==1.9.4 in ./.local/lib/python3.11/site-packages (from homeassistant) (1.9.4)
Requirement already satisfied: aiosignal>=1.1.2 in ./.local/lib/python3.11/site-packages (from aiohttp==3.9.3->homeassistant) (1.3.2)
Requirement already satisfied: frozenlist>=1.1.1 in ./.local/lib/python3.11/site-packages (from aiohttp==3.9.3->homeassistant) (1.6.2)
Requirement already satisfied: multidict<7.0,>=4.5 in ./.local/lib/python3.11/site-packages (from aiohttp==3.9.3->homeassistant) (6.4.4)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl==1.9.4->homeassistant) (3.3)
Requirement already satisfied: zlib-ng>=0.3.0 in ./.local/lib/python3.11/site-packages (from aiohttp-zlib-ng==0.3.1->homeassistant) (0.5.1)
Requirement already satisfied: pytz in /usr/lib/python3/dist-packages (from astral==2.2->homeassistant) (2022.7.1)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.11/dist-packages (from cryptography==42.0.5->homeassistant) (1.16.0)
Requirement already satisfied: pycognito==2023.5.0 in ./.local/lib/python3.11/site-packages (from hass-nabucasa==0.78.0->homeassistant) (2023.5.0)
Requirement already satisfied: snitun==0.36.2 in ./.local/lib/python3.11/site-packages (from hass-nabucasa==0.78.0->homeassistant) (0.36.2)
Requirement already satisfied: acme==2.8.0 in ./.local/lib/python3.11/site-packages (from hass-nabucasa==0.78.0->homeassistant) (2.8.0)
Requirement already satisfied: josepy>=1.13.0 in /usr/lib/python3/dist-packages (from acme==2.8.0->hass-nabucasa==0.78.0->homeassistant) (1.13.0)
Requirement already satisfied: pyrfc3339 in /usr/lib/python3/dist-packages (from acme==2.8.0->hass-nabucasa==0.78.0->homeassistant) (1.1)
Requirement already satisfied: setuptools>=41.6.0 in ./.local/lib/python3.11/site-packages (from acme==2.8.0->hass-nabucasa==0.78.0->homeassistant) (80.9.0)
Requirement already satisfied: habluetooth>=0.11.0 in ./.local/lib/python3.11/site-packages (from home-assistant-bluetooth==1.12.0->homeassistant) (3.49.0)
Requirement already satisfied: anyio in ./.local/lib/python3.11/site-packages (from httpx==0.27.0->homeassistant) (4.9.0)
Requirement already satisfied: httpcore==1.* in ./.local/lib/python3.11/site-packages (from httpx==0.27.0->homeassistant) (1.0.9)
Requirement already satisfied: sniffio in ./.local/lib/python3.11/site-packages (from httpx==0.27.0->homeassistant) (1.3.1)
Requirement already satisfied: MarkupSafe>=2.0 in /usr/local/lib/python3.11/dist-packages (from Jinja2==3.1.3->homeassistant) (2.1.5)
Requirement already satisfied: boto3>=1.10.49 in ./.local/lib/python3.11/site-packages (from pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (1.38.32)
Requirement already satisfied: envs>=1.3 in ./.local/lib/python3.11/site-packages (from pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (1.4)
Requirement already satisfied: python-jose>=3.2.0 in ./.local/lib/python3.11/site-packages (from python-jose[cryptography]>=3.2.0->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (3.5.0)
Requirement already satisfied: text-unidecode>=1.3 in ./.local/lib/python3.11/site-packages (from python-slugify==8.0.4->homeassistant) (1.3)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/lib/python3/dist-packages (from requests==2.31.0->homeassistant) (3.0.1)
Requirement already satisfied: async-timeout>=3.0.1 in ./.local/lib/python3.11/site-packages (from snitun==0.36.2->hass-nabucasa==0.78.0->homeassistant) (5.0.1)
Requirement already satisfied: h11>=0.16 in ./.local/lib/python3.11/site-packages (from httpcore==1.*->httpx==0.27.0->homeassistant) (0.16.0)
Requirement already satisfied: botocore<1.39.0,>=1.38.32 in ./.local/lib/python3.11/site-packages (from boto3>=1.10.49->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (1.38.32)
Requirement already satisfied: jmespath<2.0.0,>=0.7.1 in ./.local/lib/python3.11/site-packages (from boto3>=1.10.49->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (1.0.1)
Requirement already satisfied: s3transfer<0.14.0,>=0.13.0 in ./.local/lib/python3.11/site-packages (from boto3>=1.10.49->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (0.13.0)
Requirement already satisfied: python-dateutil<3.0.0,>=2.1 in ./.local/lib/python3.11/site-packages (from botocore<1.39.0,>=1.38.32->boto3>=1.10.49->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (2.9.0.post0)
Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil<3.0.0,>=2.1->botocore<1.39.0,>=1.38.32->boto3>=1.10.49->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (1.16.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.11/dist-packages (from cffi>=1.12->cryptography==42.0.5->homeassistant) (2.22)
Requirement already satisfied: bleak>=0.21.1 in ./.local/lib/python3.11/site-packages (from habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (0.22.3)
Requirement already satisfied: bleak-retry-connector>=3.9.0 in ./.local/lib/python3.11/site-packages (from habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (3.10.0)
Requirement already satisfied: bluetooth-adapters>=0.16.1 in ./.local/lib/python3.11/site-packages (from habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (0.21.4)
Requirement already satisfied: bluetooth-auto-recovery>=1.5.1 in ./.local/lib/python3.11/site-packages (from habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (1.5.2)
Requirement already satisfied: bluetooth-data-tools>=1.28.0 in ./.local/lib/python3.11/site-packages (from habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (1.28.1)
Requirement already satisfied: dbus-fast>=2.30.2 in ./.local/lib/python3.11/site-packages (from habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (2.44.1)
Requirement already satisfied: aiooui>=0.1.1 in ./.local/lib/python3.11/site-packages (from bluetooth-adapters>=0.16.1->habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (0.1.9)
Requirement already satisfied: uart-devices>=0.1.0 in ./.local/lib/python3.11/site-packages (from bluetooth-adapters>=0.16.1->habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (0.1.1)
Requirement already satisfied: usb-devices>=0.4.5 in ./.local/lib/python3.11/site-packages (from bluetooth-adapters>=0.16.1->habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (0.4.5)
Requirement already satisfied: PyRIC>=0.1.6.3 in ./.local/lib/python3.11/site-packages (from bluetooth-auto-recovery>=1.5.1->habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (0.1.6.3)
Requirement already satisfied: btsocket>=0.2.0 in ./.local/lib/python3.11/site-packages (from bluetooth-auto-recovery>=1.5.1->habluetooth>=0.11.0->home-assistant-bluetooth==1.12.0->homeassistant) (0.3.0)
Requirement already satisfied: ecdsa!=0.15 in ./.local/lib/python3.11/site-packages (from python-jose>=3.2.0->python-jose[cryptography]>=3.2.0->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (0.19.1)
Requirement already satisfied: rsa!=4.1.1,!=4.4,<5.0,>=4.0 in ./.local/lib/python3.11/site-packages (from python-jose>=3.2.0->python-jose[cryptography]>=3.2.0->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (4.9.1)
Requirement already satisfied: pyasn1>=0.5.0 in /usr/local/lib/python3.11/dist-packages (from python-jose>=3.2.0->python-jose[cryptography]>=3.2.0->pycognito==2023.5.0->hass-nabucasa==0.78.0->homeassistant) (0.6.0)
[  OK  ] DietPi-Software | Installing Home Assistant core module
[  OK  ] DietPi-Software | chmod +x /home/homeassistant/homeassistant-start.sh
[  OK  ] DietPi-Software | chmod +x /home/homeassistant/homeassistant-update.sh
[  OK  ] DietPi-Software | curl -sSfL https://github.com/hacs/integration/releases/latest/download/hacs.zip -o hacs.zip
[  OK  ] DietPi-Software | unzip -o hacs.zip -dhacs
[  OK  ] DietPi-Software | rm hacs.zip
[  OK  ] DietPi-Software | rm -R /mnt/dietpi_userdata/homeassistant/custom_components/hacs
[  OK  ] DietPi-Software | mkdir -p /mnt/dietpi_userdata/homeassistant/custom_components
[  OK  ] DietPi-Software | mv hacs /mnt/dietpi_userdata/homeassistant/custom_components/
[  OK  ] DietPi-Software | chown -R homeassistant:homeassistant /mnt/dietpi_userdata/homeassistant
[ INFO ] DietPi-Software | Home Assistant Community Store (HACS) has been installed in addition. To activate it, follow this guide: https://hacs.xyz/docs/configuration/basic/
 DietPi-Software
 Step: Finalising install
[ INFO ] DietPi-Software | Enabling installed services
[  OK  ] DietPi-Software | systemctl --no-reload enable home-assistant
[  OK  ] DietPi-Software | systemctl daemon-reload
2025-06-08 21:30:18 [ INFO ] DietPi-RAMlog | Storing /var/log to /var/tmp/dietpi/logs/dietpi-ramlog_store...
2025-06-08 21:30:18 [  OK  ] DietPi-RAMlog | Stored /var/log to /var/tmp/dietpi/logs/dietpi-ramlog_store.
 DietPi-Software
 Step: Install completed
Did you tried to switch to HA user
sudo -u homeassistant bash
And run hass command manually?
That seems to have done something - thanks again.
The program started and built the python dependencies. I restarted it twice once it was done compiling as per the usual instructions. If I keep the hass command running, I can also access the instance.
However, the home-assistant systemd service still is not able to restart. Same error as before ( exec: hass: not found). Rebooting did not fix this.
Unrelated to the issue at hand, but the installation is also now full of errors. My automations have all been disabled for β€œextra keys not allowed”, and Home Assistant’s logs are complaining that I need to upgrade to Python 3.12 despite the pyenv being updated to 3.13… I’m seriously regretting not doing a full system backup. I have the local HASS backups in tar format but I’m worried that they will not work with this system state.
Maybe @MichaIng has an idea why hass command is not found during service execution but working manually
See: dietpi-software: Home Assistant: remove "pyenv local" info Β· MichaIng/DietPi@38f7c98 Β· GitHub
sudo rm /home/homeassistant/.python-version
sudo systemctl restart home-assistant
That and another reinstallation fixed everything, including the broken automations and a lot of the errors! Thank you so much!
