I run dockerized version of Tailscale and use a remote address to mount an NFS disk using dietpi_drivemanager.
If I restart dietpi, docker and other services subsequently hang since dietpi now endlessly tries to mount a disk that is offline as tailscale is not up and the instance is not inside the VPN.
I had to manually sudo service portmap stop to let dietpi even properly execute the uninstall of NFS Client (even the script became unresponsive) I was also not able to kill the mount using htop
Is there a way to make the NFS client wait 5 mins (for the tailscale container to start) before executing the mount commands? A proper solution would be to mount only when a specific container is up and running, and remote IP addresses are issued.
Regards
