G4 Router 192.168.8.1
Nameserver 192.168.8.8 to Pi3
Static setting https://i.imgur.com/acE3X7o.png
WIFI on hostap
fresh Pihole , unbound and wireguard
i aktivate wireguard
start wg-quick@wg0pt
root@Pi3:~# systemctl status wg-quick@wg0pt.service
● wg-quick@wg0pt.service - WireGuard via wg-quick(8) for wg0pt
Loaded: loaded (/lib/systemd/system/wg-quick@.service; disabled; vendor preset: enabled)
Active: active (exited) since Wed 2023-06-07 18:53:45 CEST; 10s ago
Docs: man:wg-quick(8)
man:wg(8)
https://www.wireguard.com/
https://www.wireguard.com/quickstart/
https://git.zx2c4.com/wireguard-tools/about/src/man/wg-quick.8
https://git.zx2c4.com/wireguard-tools/about/src/man/wg.8
Process: 69235 ExecStart=/usr/bin/wg-quick up wg0pt (code=exited, status=0/SUCCESS)
Main PID: 69235 (code=exited, status=0/SUCCESS)
CPU: 727ms
Jun 07 18:53:44 Pi3 wg-quick[69235]: [#] ip -4 address add 10.67.164.200/32 dev wg0pt
Jun 07 18:53:45 Pi3 wg-quick[69235]: [#] ip link set mtu 1420 up dev wg0pt
Jun 07 18:53:45 Pi3 wg-quick[69267]: [#] resolvconf -a tun.wg0pt -m 0 -x
Jun 07 18:53:45 Pi3 wg-quick[69235]: [#] wg set wg0pt fwmark 51820
Jun 07 18:53:45 Pi3 wg-quick[69235]: [#] ip -4 route add 0.0.0.0/0 dev wg0pt table 51820
Jun 07 18:53:45 Pi3 wg-quick[69235]: [#] ip -4 rule add not fwmark 51820 table 51820
Jun 07 18:53:45 Pi3 wg-quick[69235]: [#] ip -4 rule add table main suppress_prefixlength 0
Jun 07 18:53:45 Pi3 wg-quick[69235]: [#] sysctl -q net.ipv4.conf.all.src_valid_mark=1
Jun 07 18:53:45 Pi3 wg-quick[69309]: [#] iptables-restore -n
Jun 07 18:53:45 Pi3 systemd[1]: Finished WireGuard via wg-quick(8) for wg0pt.
Lan = but traffic not route over wireguard
Wifi 10.42.0.1 dns 192.168.8.8 = traffic not route over wireguard
how can i fix
or
what would the optimal setting for dietpi and pihole unbound wireguard look like?
So you want to create an acces point with your RPi, which uses pihole and unbound for DNS resolution, the G4 router is you gateway and wireguard is for remote access or what do you want to achieve?
RPi acces point = OK 192.168.42.1
pihole and unbound for DNS resolution = OK 127.0.0.1.5335
G4 router is as gateway = OK
wireguard client conncet to mullvad = success but not load sites
i connect to RPi WIFI on hostap 192.168.42.1 = connect to internet works
i start systemctl start wg-quick@wg0pt
Active: active (exited) since Thu 2023-06-08 13:13:24 CEST; 3s ago
man:wg(8)
Process: 51386 ExecStart=/usr/bin/wg-quick up wg0pt (code=exited, status=0/SUCCESS)
Main PID: 51386 (code=exited, status=0/SUCCESS)
CPU: 717ms
Jun 08 13:13:24 Pi3 wg-quick[51386]: [#] ip -4 address add 10.67.164.200/32 dev wg0pt
Jun 08 13:13:24 Pi3 wg-quick[51386]: [#] ip link set mtu 1420 up dev wg0pt
Jun 08 13:13:24 Pi3 wg-quick[51417]: [#] resolvconf -a tun.wg0pt -m 0 -x
Jun 08 13:13:24 Pi3 wg-quick[51386]: [#] wg set wg0pt fwmark 51820
Jun 08 13:13:24 Pi3 wg-quick[51386]: [#] ip -4 route add 0.0.0.0/0 dev wg0pt table 51820
Jun 08 13:13:24 Pi3 wg-quick[51386]: [#] ip -4 rule add not fwmark 51820 table 51820
Jun 08 13:13:24 Pi3 wg-quick[51386]: [#] ip -4 rule add table main suppress_prefixlength 0
Jun 08 13:13:24 Pi3 wg-quick[51386]: [#] sysctl -q net.ipv4.conf.all.src_valid_mark=1
Jun 08 13:13:24 Pi3 wg-quick[51459]: [#] iptables-restore -n
Jun 08 13:13:24 Pi3 systemd[1]: Finished WireGuard via wg-quick(8) for wg0pt.
