Hello everyone,
Unfortunately, I’m currently struggling a bit with installing a fresh Bullseye installation on VMWare Esxi.
I’ve already tried to get ahead with a Google search, but unfortunately without success.
I´m using this ova template: dietpi.com/downloads/images/DietPi_ESXi-x86_64-Bullseye.ova.xz
After the login the first run starts (and fails :()
DietPi-Software
Step: Applying initial first run setup steps
[ OK ] DietPi-Software | Checking IPv4 network connectivity
[ OK ] DietPi-Software | Checking DNS resolver
[ OK ] DietPi-TimeSync | systemctl start systemd-timesyncd
[ INFO ] DietPi-TimeSync | Waiting for time sync (1/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (2/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (3/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (4/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (5/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (6/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (7/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (8/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (9/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (10/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (11/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (12/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (13/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (14/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (15/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (16/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (17/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (18/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (19/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (20/60)
[ INFO ] DietPi-TimeSync | Waiting for time sync (21/60)
[ OK ] DietPi-TimeSync | Time sync completed
[ OK ] DietPi-TimeSync | systemctl stop systemd-timesyncd
[ OK ] DietPi-TimeSync | mkdir -p /run/systemd/timesync
[ INFO ] DietPi-Software | APT update, please wait...
Hit:1 deb.debian .org/debian bullseye InRelease
Hit:2 deb.debian .org/debian bullseye-updates InRelease
Hit:3 deb.debian .org/debian-security bullseye-security InRelease
Hit:4 deb.debian .org/debian bullseye-backports InRelease
Reading package lists...
[ OK ] DietPi-Software | APT update
[ INFO ] DietPi-Software | APT dist-upgrade, please wait...
Building dependency tree...
Reading state information...
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
linux-image-amd64 : Depends: linux-image-5.10.0-28-amd64 (= 5.10.209-2) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
[FAILED] DietPi-Software | APT dist-upgrade
- Command: apt-get -y dist-upgrade
[ INFO ] DietPi-Software | Executing alternative command: apt autoremove
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
[FAILED] Alternative command execution | Exited with error
Press any key to return to error handler menu...
[ INFO ] DietPi-Software | Executing alternative command: apt --fix-broken install
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
linux-image-5.10.0-27-amd64
Use 'apt autoremove' to remove it.
The following additional packages will be installed:
Suggested packages:
linux-doc-5.10 debian-kernel-handbook
Recommended packages:
firmware-linux-free apparmor
6 not fully installed or removed.
Need to get 55.7 MB of archives.
After this operation, 318 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 deb.debian.org/debian bullseye/main amd64 linux-image-5.10.0-28-amd64 amd64 5.10.209-2 [55.7 MB]
Fetched 55.7 MB in 2s (23.3 MB/s)
(Reading database ... 17727 files and directories currently installed.)
Preparing to unpack .../linux-image-5.10.0-28-amd64_5.10.209-2_amd64.deb ...
Unpacking linux-image-5.10.0-28-amd64 (5.10.209-2) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-5.10.0-28-amd64_5.10.209-2_amd64.deb
(--unpack): cannot copy extracted data for
'./lib/modules/5.10.0-28-amd64/kernel/drivers/scsi/be2iscsi/be2iscsi.ko'
to '/lib/modules/5.10.0-28-amd64/kernel/drivers/scsi/be2iscsi/be2iscsi.ko.dpkg-new':
failed to write (No space left on device)
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@DietPi:/tmp/DietPi-Software# df -h
udev 10M 0 10M 0% /dev
/dev/sda1 897M 696M 140M 84% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 1.6G 8.5M 1.6G 1% /run
tmpfs 3.9G 12K 3.9G 1% /tmp
tmpfs 50M 32K 50M 1% /var/log
Anyone an idea why the “out of the box” deployment is not working? i already try to give the virtual machine more space, but no changes…
Thank you & kind regards
Martin
PS: I have to cut the links cause i have not the permission to use more than 2 in a post ![]()
