- DietPi has encountered an error -
- Please create a ticket: GitHub · Where software is built -
- Copy and paste only the BLUE lines below into the ticket -
Details:
- Date | Sat Sep 17 13:02:21 BST 2022
- DietPi version | v7.9.3 (MichaIng/master)
- Image creator | DietPi Core Team
- Pre-image | Armbian
- Hardware | Odroid C1 (armv7l) (ID=10)
- Kernel version |
Linux DietPi 5.10.21-meson #21.02.3 SMP Mon Mar 8 07:39:35 UTC 2021 armv7l GNU/Linux - Distro | bullseye (ID=6)
- Command |
apt-get -q update - Exit code | 255
- Software title | DietPi-Update
Additional logs:
Hit:1 https://deb.debian.org/debian-security bullseye-security InRelease
Hit:2 https://ftp.debian.org/debian bullseye InRelease
Hit:3 https://ftp.debian.org/debian bullseye-updates InRelease
Hit:4 https://ftp.debian.org/debian bullseye-backports InRelease
Err:5 http://apt.armbian.com bullseye InRelease
Could not connect to apt.armbian.com:80 (107.175.134.226). - connect (111: Connection refused)
Reading package lists...
W: Failed to fetch http://apt.armbian.com/dists/bullseye/InRelease Could not connect to apt.armbian.com:80 (107.175.134.226). - connect (111: Connection refused)
W: Some index files failed to download. They have been ignored, or old ones used instead.
so it’s a new install on an Odroid C1… it was originally an upgrade on a C1 from 8.2 to 8.8.1 but it can’t connect to the 107.175.134.226, even though I can ping it and go there in a browser.
Pinging 107.175.134.226 with 32 bytes of data:
Reply from 107.175.134.226: bytes=32 time=36ms TTL=51
Reply from 107.175.134.226: bytes=32 time=34ms TTL=51
Reply from 107.175.134.226: bytes=32 time=31ms TTL=51
I am doing a clean install using an older version of the C1 download which will boot, whereas the current one will never boot. the blue light stays on and it just hangs.
I’d like to get my 2 C1 boards in use again, they were running OctoPrint before I tried to update them now they don’t run anything.
any help would be appreciated.
