Hello
at first i want to say a really big THANKX to the developers of DietPi. I love it. For Linux noobs like me it is a great help to setup the system.
Now my question.
I have a compatible LCD on my RPi2 and DietPi-Cloudshell works fine but i want to start a Xserver. I have seen it that this shoud work but i don`t get it run. I have tried many ways.
For example in DietPi-Config → Display Options → Change Resolution to DietPi-Cloudshell and Headless.
I had have installed LXDE. But when i autostart to LXDE with DietPi-Cloudshell-resolution only my HDMI-Monitor shows LXDE. When i autostart LDXE headless i get a XServer-fail message and on the LCD i see only the console with fail messages refer to /var/log/Xorg.0.log:
[ 2641.606]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 2641.606] X Protocol Version 11, Revision 0
[ 2641.607] Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
[ 2641.607] Current Operating System: Linux DietPi 4.4.44-v7+ #2 SMP Sat Feb 11 16:07:35 UTC 2017 armv7l
[ 2641.607] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=320 bcm2708_fb.fbheight=240 bcm2709.boardrev=0xa01041 bcm2709.serial=0xbad6039c smsc95xx.macaddr=B8:27:EB:D6:03:9C bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 $
[ 2641.607] Build Date: 11 November 2016 11:59:59AM
[ 2641.607] xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
[ 2641.607] Current version of pixman: 0.33.3
[ 2641.607] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2641.607] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2641.608] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb 17 14:19:38 2017
[ 2641.609] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2641.609] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2641.611] (==) No Layout section. Using the first Screen section.
[ 2641.611] (==) No screen section available. Using defaults.
[ 2641.611] (**) |-->Screen "Default Screen Section" (0)
[ 2641.611] (**) | |-->Monitor "<default monitor>"
[ 2641.612] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 2641.612] (**) | |-->Device "Allwinner A10/A13 FBDEV"
[ 2641.612] (**) | |-->GPUDevice "FBDEV"
[ 2641.612] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 2641.612] (==) Automatically adding devices
[ 2641.613] (==) Automatically enabling devices
[ 2641.613] (==) Automatically adding GPU devices
[ 2641.613] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2641.613] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 2641.613] Entry deleted from font path.
[ 2641.613] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 2641.613] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 2641.613] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 2641.613] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 2641.613] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 2641.613] (==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
[ 2641.613] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2641.613] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2641.614] (II) Loader magic: 0x54cbef20
[ 2641.614] (II) Module ABI versions:
[ 2641.614] X.Org ANSI C Emulation: 0.4
[ 2641.614] X.Org Video Driver: 20.0
[ 2641.614] X.Org XInput driver : 22.1
[ 2641.614] X.Org Server Extension : 9.0
[ 2641.627] (--) using VT number 2
[ 2641.628] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 2641.628] (II) no primary bus or device found
[ 2641.629] (II) LoadModule: "glx"
[ 2641.634] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2641.649] (II) Module glx: vendor="X.Org Foundation"
[ 2641.649] compiled for 1.18.4, module version = 1.0.0
[ 2641.649] ABI class: X.Org Server Extension, version 9.0
[ 2641.650] (==) AIGLX enabled
[ 2641.650] (II) LoadModule: "fbturbo"
[ 2641.650] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 2641.651] (II) Module fbturbo: vendor="X.Org Foundation"
[ 2641.651] compiled for 1.18.4, module version = 0.5.1
[ 2641.651] Module class: X.Org Video Driver
[ 2641.651] ABI class: X.Org Video Driver, version 20.0
[ 2641.652] (II) LoadModule: "fbdev"
[ 2641.653] (WW) Warning, couldn't open module fbdev
[ 2641.653] (II) UnloadModule: "fbdev"
[ 2641.653] (II) Unloading fbdev
[ 2641.653] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 2641.653] (II) FBTURBO: driver for framebuffer: fbturbo
[ 2641.655] (WW) Falling back to old probe method for fbturbo
[ 2641.655] (II) Loading sub module "fbdevhw"
[ 2641.655] (II) LoadModule: "fbdevhw"
[ 2641.656] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 2641.657] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 2641.657] compiled for 1.18.4, module version = 0.0.2
[ 2641.657] ABI class: X.Org Video Driver, version 20.0
[ 2641.657] (II) FBTURBO(0): using /dev/fb0
[ 2641.657] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 2641.657] (II) FBTURBO(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 8/8
[ 2641.657] (==) FBTURBO(0): Depth 8, (==) framebuffer bpp 8
[ 2641.658] (==) FBTURBO(0): Default visual is PseudoColor
[ 2641.658] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2641.658] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 0kB)
[ 2641.658] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[ 2641.658] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[ 2641.659] (II) FBTURBO(0): processor: ARM Cortex-A7
[ 2641.659] (II) FBTURBO(0): checking modes against framebuffer device...
[ 2641.659] (II) FBTURBO(0): checking modes against monitor...
[ 2641.659] (--) FBTURBO(0): Virtual size is 16x16 (pitch 16)
[ 2641.659] (**) FBTURBO(0): Built-in mode "current"
[ 2641.659] (==) FBTURBO(0): DPI set to (96, 96)
[ 2641.659] (II) Loading sub module "fb"
[ 2641.659] (II) LoadModule: "fb"
[ 2641.660] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 2641.661] (II) Module fb: vendor="X.Org Foundation"
[ 2641.661] compiled for 1.18.4, module version = 1.0.0
[ 2641.661] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2641.663] (EE) FBTURBO(0): FBIOPUT_VSCREENINFO: Invalid argument
[ 2641.663] (EE) FBTURBO(0): mode initialization failed
[ 2641.663] (EE)
Fatal server error:
[ 2641.663] (EE) AddScreen/ScreenInit failed for driver 0
[ 2641.663] (EE)
[ 2641.663] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 2641.663] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 2641.663] (EE)
[ 2641.676] (EE) Server terminated with error (1). Closing log file.
What is my fault? Thankx for your help.
Greetings Jochen
