- DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=17
G_DIETPI_VERSION_RC=2
G_LIVE_PATCH_STATUS[1]=‘not applied’
- Distro version |
buster 0
- Kernel version |
uname -a
Linux DietPi 5.10.103-v8+ #1529 SMP PREEMPT Tue Mar 8 12:26:46 GMT 2022 aarch64 GNU/Linux
- Architecture |
dpkg --print-architecture
arm64
- SBC model |
RPi 4 Model B (aarch64)
- Power supply used | (EG: 5V 1A RAVpower)
Stock Raspberry 4 Power Plug
- SD card used | (EG: SanDisk ultra)
32GB Netac V10 A1
Samba Version 4.9.5-Debian (/usr/sbin/samba -V output)
Migrated from previously installed releases.
Not Tested / Not sure
- Bug report ID |
echo $G_HW_UUID
Any file transfer using Samba is stuck at less than 500Kb/sec, with occasional transfer errors. files are being transferred from an external SSD drive using an USB3 Enclosure. The drive is formatted as Ext4.
Using any other transfer protocol, such as SFTP, I can easily reach ~50MB/sec data transfer (the DietPi is connected using ethernet to a gigabit wireless N router, I’ve tested both windows 11 and Mac Os 13.4 as clients with the same results) .
I’ve tested the solutions suggested here:
- /forum/t/slow-samba-transfers-odroid-xu4-fix/4071 (can’t add more than two links, sorry)
- https://superuser.com/questions/713248/home-file-server-using-samba-has-slow-read-and-write-speed
and… a bunch of other places, honestly.
Given the amount of results I get from Google regarding “Raspberry PI 4 Samba Slow” It looks like it seems that for one reason or another the Raspberry Pi 4 really doesn’t like something very specific regarding the Samba Protocol. According to this thread, the actual transfer speeds should be way higher, around ~100MB/sec on real world workloads.
Before I call it quits and just keep using SFTP, I’d love to know if anyone has some specific suggestion regarding this issue.
Here’s my /etc/samba/smb.conf:
[global]
workgroup = WORKGROUP
server string = %h server
dns proxy = no
max log size = 1000
syslog only = no
syslog = 0
panic action = /usr/share/samba/panic-action %d
security = user
encrypt passwords = true
passdb backend = tdbsam
obey pam restrictions = yes
unix password sync = yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
pam password change = yes
map to guest = bad user
load printers = no
printcap name = /dev/null
disable spoolss = yes
read raw = Yes
write raw = Yes
socket options = TCP_NODELAY IPTOS_LOWDELAY
min receivefile size = 16384
use sendfile = true
aio read size = 16384
aio write size = 16384
[dietpi]
comment = DietPi Share
path = /mnt/sda1/dietpi
browseable = yes
create mask = 0664
directory mask = 0775
valid users = dietpi
Thank you,
