Every Sunday, SSH and some other services not working
@Joulinar and what about the other log file it says @Jappe?
Usually journalctl should contain everything from before reboot. But persistent logs doesn’t seem to work on your system. You can simply try your self and reboot the device. Afterwards you should see logs from before (if it is working)
Same issue here. I have DietPi installed on a S905W tvbox, and today SSH stopped working, and there are no logs from AdGuard Home, but everything else seems to work, what can it be?
@davidosdr your issue is not related, pls open an own topic and provide all necessary information
Looking at your log you are running a bunch of stuff on top of dietpi, mate, home assist, camera stuff, widgets, gnome extensions… It could be any of that other stuff causing you problems.
I know but it’s suspicious that it only fails on Sundays/Mondays…
The last time I deleted every cron I had on cron folders and it failed again…
When I woke up I plug an screen and there was an error on the screen on loop:
mmcblk0 recovery fail
Looks like an issue with the SD card.
