- DietPi version |
cat /boot/dietpi/.version8.19.1 (master, owner: MichaIng, G_LIVE_PATCH_STATUS=[applied,applied,not applied] - Distro version |
echo $G_DISTRO_NAME $G_RASPBIANbookworm 0 - Kernel version |
uname -aLinux DietPi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux - Architecture |
dpkg --print-architecturearm64 - SBC model |
echo $G_HW_MODEL_NAMEor (EG: RPi3) RPi 3 Model B+ (aarch64) - Power supply used | (EG: 5V 1A RAVpower) 5V DC 3A
- SD card used | (EG: SanDisk ultra) SanDisk Extreme 32GB
I just have a bunch of test files in /etc/cron.d/
root@DietPi:/# for f in $(find /etc/cron.d -name 'test*.sh') ; do echo ==========; echo $f; echo $(ls -la $f); echo ----------; echo $(cat $f); done
/etc/cron.d/test.sh
-rw-r--r-- 1 root root 88 Jul 22 18:05 /etc/cron.d/test.sh
*/1 * * * * root echo "Ufffi" $(date) >> /tmp/cron_d_test
*/1 * * * * dietpi ERRRORRRRR
/etc/cron.d/test4.sh
-rwxr--r-- 1 root root 77 Jul 22 18:06 /etc/cron.d/test4.sh
*/1 * * * * echo "Ufffi" $(date) >> /tmp/cron_d_test4
*/1 * * * * ERRRORRRRR
/etc/cron.d/test2.sh
-rwxr--r-- 1 root root 89 Jul 22 18:06 /etc/cron.d/test2.sh
*/1 * * * * root echo "Ufffi" $(date) >> /tmp/cron_d_test2
/etc/cron.d/test3.sh
-rw-r--r-- 1 root root 77 Jul 22 18:06 /etc/cron.d/test3.sh
*/1 * * * * echo "Ufffi" $(date) >> /tmp/cron_d_test3
Also
root@DietPi:/# cat /etc/cron.hourly/test
#!/bin/bash
echo "UFFFF" $(date) >> /tmp/hourly_test
exit 1337
See a bunch of log files in /tmp. Also see error messages in journalctl -u cron as well as error mails being sent out.
Only the cron.hourly job seems to be running (/tmp/hourly_test is logged to every hour).
However, none of the cron.d jobs are running.
I know that cron jobs for every minute are deactivated (/etc/crontab → /etc/cron.minutely). That is ok.
Still I would expect the test jobs in cron.d executed at least hourly.
I do see other jobs in /etc/cron.d being executed, though, which are not running every minute, but more on a daily basis.
I’m still kind of debugging the situation. Let me know if you need more info.
Cheers
