[✗] Check for existing repository in /var/www/html/admin
[i] Clone https://github.com/pi-hole/web.git into /var/www/html/admin...
Error: Could not update local repository. Contact support.
thanks for the fast replies
im connected on ethernet though and it worked after when i retried could the “internet problems” be why im failing the installers?
also another error now (removed parts of the links because im being limited as a new user.)
Fetched 1061 kB in 10min 36s (1667 B/s)
Reading package lists...
E: Failed to fetch deb.debian/debian/dists/bookworm/main/binary-arm64/Packages Connection timed out [IP: 199.232.58.132 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
[FAILED] DietPi-Update | APT update
- Command: apt-get -y -eany update
RPi Zero 2 W (aarch64) | IP: 192.168.0.174 | Use up/down buttons to scroll text┐
│ APT update
│ - Command: apt-get -y -eany update
│ - Exit code: 100
│ - DietPi version: v9.8.0 (MichaIng/master) | HW_MODEL: 3 | HW_ARCH: 3 |
│ DISTRO: 7
│ - Error log:
│ Get:1 dietp/apt bookworm InRelease [3538 B]
│ Get:2 dietpi/apt all InRelease [26.6 kB]
│ Get:3 dietpi/apt bookworm/rpi3 arm64 Packages [764 B]
│ Get:4 dietpi/apt bookworm/main arm64 Packages [2476 B]
│ Get:5 archive.raspberrypi/debian bookworm InRelease [39.3 kB]
│ Get:6 dietpi/apt all/rpi all Packages [436 B]
│ Get:7 deb.debian/debian bookworm InRelease [151 kB]
│ Get:8 archive.raspberrypi.com/debian bookworm/main arm64 Packages
│ [519 kB]
its been going through the installer well after i reflashed other than the internet error at the start not sure why its happening on my wifi, anyways do you know whats causing this? i cant really navigate the pihole gui because its just typing im worried if i exit this itll mess things up again LOL
it was giving me the same error i got before so i reinstalled dietpi again and will try again ill post the error text here when i probably get it again
this is the error i was getting before “Could not update local repository. Contact support.” i have searched this issue up and cannot find anything to help the problem
[i] Unable to find IPv6 ULA/GUA address
[i] IPv6 address:
[i] Using upstream DNS: Cloudflare (DNSSEC) (1.1.1.1, 1.0.0.1)
[i] Installing StevenBlack's Unified Hosts List
[i] Using privacy level: 0
[i] Check for existing repository in /etc/.pihole. [✗] Check for existing repository in /etc/.pihole
[i] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole...
that little text thing appearing on pihole is happening again do u know what im supposed to do to select continue? also i have checked with pihole support and it seems like the devs arent really actively answering unlike here…
i ended up changing something with nameserver to 1.1.1.1 and it immedietly fixed my issue if anyone is wondering not sure what i actually changed if someone wants to say it here for anyone looking for the solution
