Uh, that’s weird!
Anyway sorry but I was wrong, your suggestion doesn’t work, if I add the
dtoverlay=RPi-backlight
then
echo 1 > /sys/class/backlight/rpi_backlight/bl_power
doesn’t give me the error but the display stay ON, doesn’t turn OFF. The command does nothing…
Jappe
4 October 2022 15:44
42
I found in german RPi forum a post from 2017 (I know, it’s quite old) where they say, it doesn’t work when touch is disabled.
Hallo zusammen,
ich bin neu hier und habe folgendes Problem:
Ich will bei meinem Raspberry 3 B das Touchdisplay ausschalten
Über diesen Befehl:
Das hat eine Zeit lang auch funktioniert,...
Thanks! No the touch now is disabled, but before 8.9 I was using both touch and I was able to turn off the display.
Found the solution to turn on-off the display!
That is too stupid to be real…but… something is different in 8.9, in order to turn on/off the display, the path is different
from
to
/sys/class/backlight/backlight/bl_power
I spent days to try to load different driver from vc4-kms-dpi, the old vc4-fkms-dpi etc… but all that was needed was just to change the path
but this has no real relation to our DietPi version. We don’t maintain in /sys/class/backlight/backlight/bl_power or /sys/class/backlight/rpi_backlight/bl_power. Probably some other apt packages (like kernel) got updated in parallel.
I know! But for some reason something has changed,
I suspect this is something related to the
raspberrypi-sys-mods
Package that has been updated. Or the kernel or eeprom as you said!
