Oh I didn’t know, maybe is trying to run it because ifupdown fails?!
Anyway is not running, so it’s correct:
root@Pi-Hole:~# service network-manager stop
Failed to stop network-manager.service: Unit network-manager.service not loaded.
Yes, this is the issue. Indeed is not running:
root@Pi-Hole:~# systemctl status ifupdown-pre.service
● ifupdown-pre.service - Helper to synchronize boot up for ifupdown
Loaded: loaded (/lib/systemd/system/ifupdown-pre.service; static)
Drop-In: /etc/systemd/system/ifupdown-pre.service.d
└─dietpi.conf
Active: failed (Result: exit-code) since Thu 2022-09-29 07:42:44 CEST; 19min ago
Process: 164 ExecStart=/bin/dash -c [ "$CONFIGURE_INTERFACES" = "no" ] || [ ! -x /bin/udevadm ] || udevadm settle (code=exited, status=1/FAILURE)
Main PID: 164 (code=exited, status=1/FAILURE)
CPU: 6.998s
Sep 29 07:40:35 Pi-Hole systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Sep 29 07:42:44 Pi-Hole systemd[1]: ifupdown-pre.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 07:42:44 Pi-Hole systemd[1]: ifupdown-pre.service: Failed with result 'exit-code'.
Sep 29 07:42:44 Pi-Hole systemd[1]: Failed to start Helper to synchronize boot up for ifupdown.
Sep 29 07:42:44 Pi-Hole systemd[1]: ifupdown-pre.service: Consumed 6.998s CPU time.
root@Pi-Hole:~#
But if i try to enable it, it works, but at the reboot it hangs again ![]()
└─dietpi.conf
Active: active (exited) since Thu 2022-09-29 07:40:26 CEST; 3s ago
Process: 2275017 ExecStart=/bin/dash -c [ "$CONFIGURE_INTERFACES" = "no" ] || [ ! -x /bin/udevadm ] || udevadm settle (code=exited, status=0/SUCCESS)
Main PID: 2275017 (code=exited, status=0/SUCCESS)
CPU: 14ms
Sep 29 07:40:26 Pi-Hole systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Sep 29 07:40:26 Pi-Hole systemd[1]: Finished Helper to synchronize boot up for ifupdown.
How can I find which service is the culprit? Maybe I have to “say” to ifupdown the interface where to listen?
But I haven’t changed anything, only the eth0 is up, I disabled wifi and Bluetooth .
what is the output of
journalctl -u ifupdown-pre.service
Nothing helpful I suspect… I already tried it.
root@Pi-Hole:~# journalctl -u ifupdown-pre.service
-- Journal begins at Thu 2022-09-29 14:39:30 CEST, ends at Thu 2022-09-29 15:32:12 CEST. --
Sep 29 14:39:30 Pi-Hole systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Sep 29 14:41:40 Pi-Hole systemd[1]: ifupdown-pre.service: Main process exited, code=exited, status=1/FAILURE
Sep 29 14:41:40 Pi-Hole systemd[1]: ifupdown-pre.service: Failed with result 'exit-code'.
Sep 29 14:41:40 Pi-Hole systemd[1]: Failed to start Helper to synchronize boot up for ifupdown.
Sep 29 14:41:40 Pi-Hole systemd[1]: ifupdown-pre.service: Consumed 6.933s CPU time.
root@Pi-Hole:~#
I also tried to change “something stupid” in the network config, just to rewrite the file, but also this didn’t worked.
As I said, udev is not settling, so ifupdown-pre times out, not necessarily related to the network adapter at all. Which hardware/peripherals do you have attached to this RPi?
I have attached a SSD external drive, nothing else.
There’s an error here:
[ 2.268315] gpio-backlight backlight: Error: The gpios parameter is missing or invalid.
[ 2.268859] gpio-backlight: probe of backlight failed with error -16
[ 2.272478] gpio-10 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 2.274057] gpio-11 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
yes I changed the LED config using DietPI-led_control (disabled all), but I already tried to reset it.
Could the led service be the cause for dev hang?
Full dmesg
root@Pi-Hole:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.15.61-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003e5fffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003e5fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003e5fffff]
[ 0.000000] On node 0, zone DMA: 6656 pages in unavailable ranges
[ 0.000000] percpu: Embedded 28 pages/cpu s77272 r8192 d29224 u114688
[ 0.000000] pcpu-alloc: s77272 r8192 d29224 u114688 alloc=28*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 251496
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:BA:E4:C2 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 root=PARTUUID=9ecd0193-02 rootfstype=ext4 rootwait fsck.repair=yes net.ifnames=0 logo.nologo console=tty1
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 913044K/1021952K available (11520K kernel code, 1956K rwdata, 4140K rodata, 3840K init, 974K bss, 43372K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 38040 entries in 149 pages
[ 0.000000] ftrace: allocated 149 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000164] Console: colour dummy device 80x25
[ 0.000382] printk: console [tty1] enabled
[ 0.000413] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000430] pid_max: default: 32768 minimum: 301
[ 0.000492] LSM: Security Framework initializing
[ 0.000609] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000630] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001234] cgroup: Disabling memory control group subsystem
[ 0.002420] rcu: Hierarchical SRCU implementation.
[ 0.002976] EFI services will not be available.
[ 0.003232] smp: Bringing up secondary CPUs ...
[ 0.003715] Detected PIPT I-cache on CPU1
[ 0.003761] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.004325] Detected PIPT I-cache on CPU2
[ 0.004347] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.004825] Detected PIPT I-cache on CPU3
[ 0.004845] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.004906] smp: Brought up 1 node, 4 CPUs
[ 0.004943] SMP: Total of 4 processors activated.
[ 0.004952] CPU features: detected: 32-bit EL0 Support
[ 0.004959] CPU features: detected: 32-bit EL1 Support
[ 0.004968] CPU features: detected: CRC32 instructions
[ 0.018205] CPU: All CPU(s) started at EL2
[ 0.018254] alternatives: patching kernel code
[ 0.019043] devtmpfs: initialized
[ 0.024020] Enabled cp15_barrier support
[ 0.024060] Enabled setend support
[ 0.024072] KASLR enabled
[ 0.024177] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.024201] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.025518] pinctrl core: initialized pinctrl subsystem
[ 0.025967] DMI not present or invalid.
[ 0.026326] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.028180] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.028356] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.028753] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.028812] audit: initializing netlink subsys (disabled)
[ 0.028965] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
[ 0.029219] thermal_sys: Registered thermal governor 'step_wise'
[ 0.029322] cpuidle: using governor menu
[ 0.029471] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.029562] ASID allocator initialised with 32768 entries
[ 0.029643] Serial: AMBA PL011 UART driver
[ 0.034384] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.044060] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-08-26T14:03:33, variant start_cd
[ 0.048067] raspberrypi-firmware soc:firmware: Firmware hash is 102f1e848393c2112206fadffaaf86db04e98326
[ 0.069785] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.071458] vgaarb: loaded
[ 0.071659] SCSI subsystem initialized
[ 0.071755] usbcore: registered new interface driver usbfs
[ 0.071782] usbcore: registered new interface driver hub
[ 0.071813] usbcore: registered new device driver usb
[ 0.071965] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.072064] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.072257] pps_core: LinuxPPS API ver. 1 registered
[ 0.072267] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.072282] PTP clock support registered
[ 0.072979] clocksource: Switched to clocksource arch_sys_counter
[ 0.109211] VFS: Disk quotas dquot_6.6.0
[ 0.109284] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.109370] FS-Cache: Loaded
[ 0.109504] CacheFiles: Loaded
[ 0.113950] NET: Registered PF_INET protocol family
[ 0.114111] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.114877] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.114907] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.114922] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.114959] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.115075] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.115199] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.115219] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.115332] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.115748] RPC: Registered named UNIX socket transport module.
[ 0.115763] RPC: Registered udp transport module.
[ 0.115771] RPC: Registered tcp transport module.
[ 0.115778] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.115792] PCI: CLS 0 bytes, default 64
[ 0.116916] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.117105] kvm [1]: IPA Size Limit: 44 bits
[ 0.117605] kvm [1]: vgic interrupt IRQ9
[ 0.117737] kvm [1]: Hyp mode initialized successfully
[ 0.443376] Initialise system trusted keyrings
[ 0.443582] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.446332] zbud: loaded
[ 0.447143] FS-Cache: Netfs 'nfs' registered for caching
[ 0.447502] NFS: Registering the id_resolver key type
[ 0.447527] Key type id_resolver registered
[ 0.447535] Key type id_legacy registered
[ 0.447584] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.447595] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.448135] Key type asymmetric registered
[ 0.448147] Asymmetric key parser 'x509' registered
[ 0.448188] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.448320] io scheduler mq-deadline registered
[ 0.448331] io scheduler kyber registered
[ 0.451708] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.451741] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.451781] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 0.451818] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x003fffffff -> 0x0400000000
[ 0.515044] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 0.515197] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.515210] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.515221] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 0.515268] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.515382] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.517050] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.517243] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.517336] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.517613] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.530456] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.530485] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.530498] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.530523] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.530536] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.530922] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.538261] Console: switching to colour frame buffer device 100x30
[ 0.540084] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 800x480
[ 0.544551] iproc-rng200 fe104000.rng: hwrng registered
[ 0.544727] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[ 0.545294] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.550746] brd: module loaded
[ 0.555533] loop: module loaded
[ 0.556313] Loading iSCSI transport class v2.0-870.
[ 0.558899] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.617048] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 0.617976] usbcore: registered new interface driver r8152
[ 0.618403] usbcore: registered new interface driver lan78xx
[ 0.618812] usbcore: registered new interface driver smsc95xx
[ 0.664247] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.664808] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.665216] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.665966] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 0.667213] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.667598] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.667982] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.668538] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.668931] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.669327] usb usb1: Product: xHCI Host Controller
[ 0.669708] usb usb1: Manufacturer: Linux 5.15.61-v8+ xhci-hcd
[ 0.670097] usb usb1: SerialNumber: 0000:01:00.0
[ 0.670791] hub 1-0:1.0: USB hub found
[ 0.671231] hub 1-0:1.0: 1 port detected
[ 0.672074] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.672458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.672833] usb usb2: Product: xHCI Host Controller
[ 0.673217] usb usb2: Manufacturer: Linux 5.15.61-v8+ xhci-hcd
[ 0.673582] usb usb2: SerialNumber: 0000:01:00.0
[ 0.674198] hub 2-0:1.0: USB hub found
[ 0.674603] hub 2-0:1.0: 4 ports detected
[ 0.675707] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.676158] dwc_otg: FIQ enabled
[ 0.676163] dwc_otg: NAK holdoff enabled
[ 0.676167] dwc_otg: FIQ split-transaction FSM enabled
[ 0.676172] Module dwc_common_port init
[ 0.676452] usbcore: registered new interface driver uas
[ 0.676850] usbcore: registered new interface driver usb-storage
[ 0.677310] mousedev: PS/2 mouse device common for all mice
[ 0.679723] sdhci: Secure Digital Host Controller Interface driver
[ 0.680092] sdhci: Copyright(c) Pierre Ossman
[ 0.680648] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.684302] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.684895] hid: raw HID events driver (C) Jiri Kosina
[ 0.685365] usbcore: registered new interface driver usbhid
[ 0.685737] usbhid: USB HID core driver
[ 0.686258] ashmem: initialized
[ 0.689557] NET: Registered PF_PACKET protocol family
[ 0.690055] Key type dns_resolver registered
[ 0.691023] registered taskstats version 1
[ 0.691459] Loading compiled-in X.509 certificates
[ 0.692186] Key type ._fscrypt registered
[ 0.692585] Key type .fscrypt registered
[ 0.692925] Key type fscrypt-provisioning registered
[ 0.698403] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 0.699006] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.699556] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 17, base_baud = 0) is a PL011 rev2
[ 0.706083] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.706659] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.708615] of_cfs_init
[ 0.709117] of_cfs_init: OK
[ 0.744488] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 0.745079] Waiting for root device PARTUUID=9ecd0193-02...
[ 0.845240] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 0.846206] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
[ 0.848660] mmcblk0: p1 p2
[ 0.849478] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
[ 0.866958] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 0.867788] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.873056] devtmpfs: mounted
[ 0.877541] Freeing unused kernel memory: 3840K
[ 0.878067] Run /sbin/init as init process
[ 0.878463] with arguments:
[ 0.878467] /sbin/init
[ 0.878471] with environment:
[ 0.878474] HOME=/
[ 0.878478] TERM=linux
[ 0.933006] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.083607] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.084054] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.084485] usb 1-1: Product: USB2.0 Hub
[ 1.086047] hub 1-1:1.0: USB hub found
[ 1.086627] hub 1-1:1.0: 4 ports detected
[ 1.194428] systemd[1]: System time before build time, advancing clock.
[ 1.213294] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.238525] usb 2-2: New USB device found, idVendor=0781, idProduct=5583, bcdDevice= 1.00
[ 1.238974] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.239409] usb 2-2: Product: SanDisk 3.2Gen1
[ 1.239832] usb 2-2: Manufacturer: USB
[ 1.240252] usb 2-2: SerialNumber: 0101c109a92892f3ce021c4b683da35e66a08836bf90b7710f6d1a4dca085df7935c000000000000000000000bb37a89ff061b00835581078b28c9bb
[ 1.242609] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 1.243403] scsi host0: usb-storage 2-2:1.0
[ 1.297583] NET: Registered PF_INET6 protocol family
[ 1.299031] Segment Routing with IPv6
[ 1.299551] In-situ OAM (IOAM) with IPv6
[ 1.333493] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 1.335163] systemd[1]: Detected architecture arm64.
[ 1.342645] systemd[1]: Set hostname to <Pi-Hole>.
[ 1.678877] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.681669] systemd[1]: Created slice system-getty.slice.
[ 1.683458] systemd[1]: Created slice system-modprobe.slice.
[ 1.684828] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 1.686133] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1.687346] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.688868] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.690629] systemd[1]: Reached target Local Encrypted Volumes.
[ 1.691849] systemd[1]: Reached target Paths.
[ 1.693059] systemd[1]: Reached target Remote File Systems.
[ 1.694223] systemd[1]: Reached target Slices.
[ 1.695393] systemd[1]: Reached target Swap.
[ 1.696860] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 1.698295] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 1.700137] systemd[1]: Listening on Journal Audit Socket.
[ 1.701697] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.703222] systemd[1]: Listening on Journal Socket.
[ 1.707129] systemd[1]: Listening on udev Control Socket.
[ 1.708591] systemd[1]: Listening on udev Kernel Socket.
[ 1.709736] systemd[1]: Reached target Sockets.
[ 1.711156] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 1.713495] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.717272] systemd[1]: Mounting Kernel Debug File System...
[ 1.721341] systemd[1]: Mounting Kernel Trace File System...
[ 1.726708] systemd[1]: Starting Restore / save the current clock...
[ 1.734211] systemd[1]: Starting Set the console keyboard layout...
[ 1.737969] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 1.742231] systemd[1]: Starting Load Kernel Module configfs...
[ 1.747182] systemd[1]: Starting Load Kernel Module fuse...
[ 1.752329] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 1.756654] systemd[1]: Starting File System Check on Root Device...
[ 1.762930] systemd[1]: Starting Journal Service...
[ 1.770127] systemd[1]: Starting Load Kernel Modules...
[ 1.774373] systemd[1]: Starting Coldplug All udev Devices...
[ 1.783938] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.799595] systemd[1]: Mounted Kernel Debug File System.
[ 1.803599] systemd[1]: Mounted Kernel Trace File System.
[ 1.805181] fuse: init (API version 7.34)
[ 1.809823] systemd[1]: Finished Restore / save the current clock.
[ 1.812538] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 1.815224] systemd[1]: modprobe@configfs.service: Succeeded.
[ 1.816220] systemd[1]: Finished Load Kernel Module configfs.
[ 1.818865] systemd[1]: modprobe@fuse.service: Succeeded.
[ 1.820182] systemd[1]: Finished Load Kernel Module fuse.
[ 1.822675] systemd[1]: Finished Load Kernel Modules.
[ 1.827048] systemd[1]: Mounting FUSE Control File System...
[ 1.831278] systemd[1]: Mounting Kernel Configuration File System...
[ 1.837340] systemd[1]: Started File System Check Daemon to report status.
[ 1.841637] systemd[1]: Starting Apply Kernel Variables...
[ 1.846466] systemd[1]: Mounted FUSE Control File System.
[ 1.847948] systemd[1]: Mounted Kernel Configuration File System.
[ 1.898767] systemd[1]: Finished Apply Kernel Variables.
[ 1.924614] systemd[1]: Finished File System Check on Root Device.
[ 1.928339] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.930458] systemd[1]: Started Journal Service.
[ 2.015172] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 2.134474] systemd-journald[137]: Received client request to flush runtime journal.
[ 2.275194] scsi 0:0:0:0: Direct-Access USB SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6
[ 2.294787] sd 0:0:0:0: [sda] 60088320 512-byte logical blocks: (30.8 GB/28.7 GiB)
[ 2.296127] sd 0:0:0:0: [sda] Write Protect is off
[ 2.296683] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 2.297541] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2.312173] i2c-gpio i2c@0: using lines 10 (SDA) and 11 (SCL)
[ 2.318940] sda: sda1
[ 2.327899] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 2.341271] spi spi7.0: Fixing up cyclic dependency with fe208000.dpi
[ 2.350463] mc: Linux media interface: v0.10
[ 2.390057] videodev: Linux video capture interface: v2.00
[ 2.463996] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 2.469040] rpivid feb10000.codec: Device registered as /dev/video19
[ 2.611225] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.394765] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 3.396755] bcmgenet fd580000.ethernet eth0: Link is Down
[ 7.485189] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 31.709092] cam-dummy-reg: disabling
I found another very weird thing, the command that I use every day and with cron to turn on-off the attached screen in the night…doesn’t work anymore ![]()
root@Pi-Hole:~# echo 0 > /sys/class/backlight/rpi_backlight/bl_power
-bash: /sys/class/backlight/rpi_backlight/bl_power: No such file or directory
But I’ve never deleted, or modified, or even touched something related to it!
How can I install-reinstall the package/s related to backlight for LEDs, screen, etc…? I have no idea which apt packet is because I’ve never deleted it? (is not the RPi-backlight python module, I’ve never installed it). Or something to check if all the packages are installed, repair DietPI, I don’t know… otherwise I have to reinstall all I think.
Hmm that sysfs entry must exist. It’s created by the kernel at boot. It is used by official RPi services as well: raspberrypi-sys-mods/raspberrypi-sys-mods.rpi-display-backlight.service at master · RPi-Distro/raspberrypi-sys-mods · GitHub
How is the external SSD powered, via dedicated PSU or via USB only? Does it work reliably?
It seems you have I2C enabled. Do you require it for something, else could you try to disable it?
Exactly, it was there until few days ago. I have no idea why it disappears.
The external SSD is USB powered and it works very well.
Enabled? I’ve never enabled it… DietPI tool reports it as OFF.
What’s is going on in my Pi-Hole?
maybe a clean install and a restore of Pi-Hole data will fix it… but I still would try to fix it if possible.
Let’s try to reinstall the kernel:
apt install --reinstall raspberrypi-kernel raspberrypi-bootloader
Also can you show:
grep -v '^[[:blank:]]*#' /boot/config.txt
EDIT: While currently nothing indicates it explicitly, at least you could try to put the SSD into a self-powered hub/docking station. The RPi USB ports are not designed to power 2.5" drives. The overall 6 W max power are easily hit on usage peaks and during boot, causing possible issues.
Done it, without success… at the boot is still stucked for 2 minutes.
Here it is (I removed the huge blank spaces), as you can see I have never enabled the I2C interface.
root@Pi-Hole:~# grep -v '^[[:blank:]]*#' /boot/config.txt
framebuffer_width=800
framebuffer_height=480
hdmi_blanking=1
disable_overscan=0
disable_camera_led=1
gpu_mem_256=16
gpu_mem_512=16
gpu_mem_1024=16
disable_splash=1
dtparam=audio=off
enable_uart=0
dtparam=sd_poll_once
temp_limit=75
initial_turbo=20
arm_64bit=1
dtoverlay=disable-wifi
dtoverlay=vc4-kms-dpi-hyperpixel4,rotate=270
dtoverlay=vc4-kms-v3d
root@Pi-Hole:~#
Yes, sorry, what a stupid, this RaspberryPI 4 doesn’t have anything attached to it, is another RaspberryPI that I’m using as a Prometheus and Grafana server that has the NVME disk attached.
(PS: the RaspberryPI with the SSD is running perfect with DietPI and the latest update… only this RaspberryPI/Pi-Hole has this weird issue)
Okay… I was annoyed and
I’ve just reinstalled everything
and I found the issue! Finally
The trouble is that when I enable the driver for the Pimoroni HyperPixel screen it hangs at boot!
As soon as I add to config.txt
The boot hangs for 2 minutes. I have no idea why. Just comment the lines above and it starts in few seconds (but obviously the screen doesn’t work without the two lines/drivers).
I see from the changeling that you @MichaIng have changed something in raspberrypi-sys-mods with 8.9. So this is the issue:
The
raspberrypi-sys-mods packagehas been replaced with an own one, using only the small subset of the contained tweaks, which are useful on DietPi as well. A recent update of the package added a large number of dependencies, required for rpi-imager setup steps on Raspberry Pi OS only: MichaIng/DietPi#5734
If you want I can help you to investigate the issue, reporting logs, info, etcc… but at least I found the issue.
I can wait two minutes at boot, there’s no problem, I reboot it once in months but this issue should be fixed, because it can cause issue also with other displays I think!
tvservice is not supported when using the vc4-kms-v3d driver.
Okay, great that root found it.
The tvservice thing is known, but easier to just run compared to always first check whether KMS is enabled.
I’ll have a look into the raspberrypi-sys-mods package. Probably I missed something to port over.
Ah, the issue then is that I2C is disabled while the touch screen driver attempts to use it. To disable it, set the overlay to:
dtoverlay=vc4-kms-dpi-hyperpixel4,rotate=270,disable-touch
Great thanks, this worked for the boot hanging but I’m still unable to turn the display ON/OFF using my “normal” command, do you know why by chance?
root@Pi-Hole:~# echo 1 > /sys/class/backlight/rpi_backlight/bl_power
I guess you need to activate the dtoverlay=rpi-backlight first. Just place it to the end of /boot/config.txt.
Great! This worked thanks!
But why with the release 8.9 all the dt-overlays are disabled/messed up?
I don’t know. At least from our side we did not touch the /boot/config.txt.
