As a workaround, can you wait for 5 minutes before hitting retry? Looks like a parallel update process is started in background which should not be the case.
I tried again and this time I got to this error again.
I did as you said and waited 5+ minutes and hit .
However, in the end I end up with the same as in the other error linked above (Initial Boot “Time Sync timed out”…)
Namely the following flickering in the top left corner of the screen:
[ INFO ] Dietpi-Software | Dietpi has not fully been installed.
This must be completet prior to using DietPi by selecting:
- Go Start Install.
Yes, we have spam protection. Unfortunately, this is necessary to exclude spam bots. I have now added you as a basic member and you should have a bit more freedom to post.
OK, let’s try to solve your two problems one by one. First, you can flash a new image and not customise the dietpi.txt, just use the default one. Once this is done, boot your device and try to connect via SSH. You should now be prompted to start the initial setup process. If you encounter a problem, you should be able to scroll up a little in your SSH session and copy/paste the error message.
well, I opted for a manual install already (no change to dietpi.txt) and I experienced no problems at all.
Appears to me that automated install has some issues.
I will have to install the old system back again due to a forgotten psql migration. So if you need any more data/tests, let me know. I think I could squeeze one or two more SD card unstick and restick into today ; ).
After several manual installs, I can say that manual installations are very stable. So far no issues.
I’m already quite for, so will probably not want to waste the system again ; ).
