Does an .iso unpacker exist for DietPi?
Hi there,
Is there a app that works within DietPi for unpacking .iso files, ideally within a set up that includes Radarr/Sonarr? I’ve come across Unpackerr but it doesn’t appear in the DietPi software list.
Many thanks
You can install every software same way as you would do on a Debian system. You are not limited to our software catalogue.
Thanks for the prompt reply - much appreciated.
I’ve actually decided that I will go down a nzb only route as torrents seem to be where all the ISO - some of which look a bit dodgy - are coming from
You can just mount them like drives and then have a look inside:
sudo mkdir /mnt/iso
sudo mount -o loop image.iso /mnt/iso
