Be happy to help!
journalctl.txt (14.1 KB)
root@DietPi:~# journalctl -u home-assistant
Jul 20 05:09:21 DietPi systemd[1]: Started home-assistant.service - Home Assistant (DietPi).
Jul 20 05:09:23 DietPi Home Assistant[569]: 2026-07-20 05:09:23.711 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Jul 20 05:09:23 DietPi Home Assistant[569]: 2026-07-20 05:09:23.946 WARNING (MainThread) [zeroconf] Address not available when binding to ('fd18:c91e:498e:a9da:be24:11ff:feb0:16e4', 5353, 0, 0), it is expected to happen on some systems
Jul 20 05:09:23 DietPi Home Assistant[569]: 2026-07-20 05:09:23.989 ERROR (MainThread) [haffmpeg.core] FFmpeg fails [Errno 2] No such file or directory: 'ffmpeg'
Jul 20 05:09:23 DietPi Home Assistant[569]: Traceback (most recent call last):
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/haffmpeg/core.py", line 130, in open
Jul 20 05:09:23 DietPi Home Assistant[569]: self._proc = await asyncio.create_subprocess_exec(
Jul 20 05:09:23 DietPi Home Assistant[569]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:23 DietPi Home Assistant[569]: ...<6 lines>...
Jul 20 05:09:23 DietPi Home Assistant[569]: )
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/asyncio/subprocess.py", line 224, in create_subprocess_exec
Jul 20 05:09:23 DietPi Home Assistant[569]: transport, protocol = await loop.subprocess_exec(
Jul 20 05:09:23 DietPi Home Assistant[569]: ...<3 lines>...
Jul 20 05:09:23 DietPi Home Assistant[569]: stderr=stderr, **kwds)
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/asyncio/base_events.py", line 1808, in subprocess_exec
Jul 20 05:09:23 DietPi Home Assistant[569]: transport = await self._make_subprocess_transport(
Jul 20 05:09:23 DietPi Home Assistant[569]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:23 DietPi Home Assistant[569]: protocol, popen_args, False, stdin, stdout, stderr,
Jul 20 05:09:23 DietPi Home Assistant[569]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:23 DietPi Home Assistant[569]: bufsize, **kwargs)
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/asyncio/unix_events.py", line 203, in _make_subprocess_transport
Jul 20 05:09:23 DietPi Home Assistant[569]: transp = _UnixSubprocessTransport(self, protocol, args, shell,
Jul 20 05:09:23 DietPi Home Assistant[569]: stdin, stdout, stderr, bufsize,
Jul 20 05:09:23 DietPi Home Assistant[569]: waiter=waiter, extra=extra,
Jul 20 05:09:23 DietPi Home Assistant[569]: **kwargs)
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/asyncio/base_subprocess.py", line 40, in __init__
Jul 20 05:09:23 DietPi Home Assistant[569]: self._start(args=args, shell=shell, stdin=stdin, stdout=stdout,
Jul 20 05:09:23 DietPi Home Assistant[569]: ~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:23 DietPi Home Assistant[569]: stderr=stderr, bufsize=bufsize, **kwargs)
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/asyncio/unix_events.py", line 845, in _start
Jul 20 05:09:23 DietPi Home Assistant[569]: self._proc = subprocess.Popen(
Jul 20 05:09:23 DietPi Home Assistant[569]: ~~~~~~~~~~~~~~~~^
Jul 20 05:09:23 DietPi Home Assistant[569]: args, shell=shell, stdin=stdin, stdout=stdout, stderr=stderr,
Jul 20 05:09:23 DietPi Home Assistant[569]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:23 DietPi Home Assistant[569]: universal_newlines=False, bufsize=bufsize, **kwargs)
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/subprocess.py", line 1039, in __init__
Jul 20 05:09:23 DietPi Home Assistant[569]: self._execute_child(args, executable, preexec_fn, close_fds,
Jul 20 05:09:23 DietPi Home Assistant[569]: ~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:23 DietPi Home Assistant[569]: pass_fds, cwd, env,
Jul 20 05:09:23 DietPi Home Assistant[569]: ...<5 lines>...
Jul 20 05:09:23 DietPi Home Assistant[569]: gid, gids, uid, umask,
Jul 20 05:09:23 DietPi Home Assistant[569]: start_new_session, process_group)
Jul 20 05:09:23 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/subprocess.py", line 1990, in _execute_child
Jul 20 05:09:23 DietPi Home Assistant[569]: raise child_exception_type(errno_num, err_msg, err_filename)
Jul 20 05:09:23 DietPi Home Assistant[569]: FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg'
Jul 20 05:09:23 DietPi Home Assistant[569]: 2026-07-20 05:09:23.995 WARNING (MainThread) [haffmpeg.tools] Error starting FFmpeg.
Jul 20 05:09:24 DietPi Home Assistant[569]: 2026-07-20 05:09:24.031 ERROR (MainThread) [homeassistant.setup] Setup failed for 'usb': Unable to import component: No module named 'aioesphomeapi'
Jul 20 05:09:24 DietPi Home Assistant[569]: Traceback (most recent call last):
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/setup.py", line 341, in _async_setup_component
Jul 20 05:09:24 DietPi Home Assistant[569]: component = await integration.async_get_component()
Jul 20 05:09:24 DietPi Home Assistant[569]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/loader.py", line 1042, in async_get_component
Jul 20 05:09:24 DietPi Home Assistant[569]: self._component_future.result()
Jul 20 05:09:24 DietPi Home Assistant[569]: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/loader.py", line 1022, in async_get_component
Jul 20 05:09:24 DietPi Home Assistant[569]: comp = await self.hass.async_add_import_executor_job(
Jul 20 05:09:24 DietPi Home Assistant[569]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:24 DietPi Home Assistant[569]: self._get_component, True
Jul 20 05:09:24 DietPi Home Assistant[569]: )
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/concurrent/futures/thread.py", line 86, in run
Jul 20 05:09:24 DietPi Home Assistant[569]: result = ctx.run(self.task)
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/concurrent/futures/thread.py", line 73, in run
Jul 20 05:09:24 DietPi Home Assistant[569]: return fn(*args, **kwargs)
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/loader.py", line 1082, in _get_component
Jul 20 05:09:24 DietPi Home Assistant[569]: ComponentProtocol, importlib.import_module(self.pkg_path)
Jul 20 05:09:24 DietPi Home Assistant[569]: ~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/util/loop.py", line 201, in protected_loop_func
Jul 20 05:09:24 DietPi Home Assistant[569]: return func(*args, **kwargs)
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.local/share/uv/python/cpython-3.14.6-linux-x86_64-gnu/lib/python3.14/importlib/__init__.py", line 88, in import_module
Jul 20 05:09:24 DietPi Home Assistant[569]: return _bootstrap._gcd_import(name[level:], package, level)
Jul 20 05:09:24 DietPi Home Assistant[569]: ~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 20 05:09:24 DietPi Home Assistant[569]: File "<frozen importlib._bootstrap>", line 1406, in _gcd_import
Jul 20 05:09:24 DietPi Home Assistant[569]: File "<frozen importlib._bootstrap>", line 1371, in _find_and_load
Jul 20 05:09:24 DietPi Home Assistant[569]: File "<frozen importlib._bootstrap>", line 1342, in _find_and_load_unlocked
Jul 20 05:09:24 DietPi Home Assistant[569]: File "<frozen importlib._bootstrap>", line 938, in _load_unlocked
Jul 20 05:09:24 DietPi Home Assistant[569]: File "<frozen importlib._bootstrap_external>", line 759, in exec_module
Jul 20 05:09:24 DietPi Home Assistant[569]: File "<frozen importlib._bootstrap>", line 491, in _call_with_frames_removed
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/components/usb/__init__.py", line 36, in <module>
Jul 20 05:09:24 DietPi Home Assistant[569]: from .serial_proxy_stub import register_serialx_transport
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/components/usb/serial_proxy_stub.py", line 6, in <module>
Jul 20 05:09:24 DietPi Home Assistant[569]: from serialx.platforms.serial_esphome import ESPHomeSerial, ESPHomeSerialTransport
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/serialx/platforms/serial_esphome.py", line 36, in <module>
Jul 20 05:09:24 DietPi Home Assistant[569]: from aioesphomeapi.client import APIClient
Jul 20 05:09:24 DietPi Home Assistant[569]: ModuleNotFoundError: No module named 'aioesphomeapi'
Jul 20 05:09:24 DietPi Home Assistant[569]: 2026-07-20 05:09:24.038 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'bluetooth'. Setup failed for dependencies: ['usb']
Jul 20 05:09:24 DietPi Home Assistant[569]: 2026-07-20 05:09:24.038 ERROR (MainThread) [homeassistant.setup] Setup failed for 'bluetooth': Could not setup dependencies: usb
Jul 20 05:09:24 DietPi Home Assistant[569]: 2026-07-20 05:09:24.657 ERROR (ImportExecutor_0) [homeassistant.components.camera.img_util] Error loading libturbojpeg; Camera snapshot performance will be sub-optimal
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/homeassistant/components/camera/img_util.py", line 91, in __init__
Jul 20 05:09:24 DietPi Home Assistant[569]: TurboJPEGSingleton.__instance = TurboJPEG()
Jul 20 05:09:24 DietPi Home Assistant[569]: ~~~~~~~~~^^
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/turbojpeg.py", line 301, in __init__
Jul 20 05:09:24 DietPi Home Assistant[569]: self.__find_turbojpeg() if lib_path is None else lib_path)
Jul 20 05:09:24 DietPi Home Assistant[569]: ~~~~~~~~~~~~~~~~~~~~~^^
Jul 20 05:09:24 DietPi Home Assistant[569]: File "/opt/homeassistant/.venv/lib/python3.14/site-packages/turbojpeg.py", line 996, in __find_turbojpeg
Jul 20 05:09:24 DietPi Home Assistant[569]: raise RuntimeError(
Jul 20 05:09:24 DietPi Home Assistant[569]: ...<2 lines>...
Jul 20 05:09:24 DietPi Home Assistant[569]: 'e.g. jpeg = TurboJPEG(lib_path)')
Jul 20 05:09:24 DietPi Home Assistant[569]: RuntimeError: Unable to locate turbojpeg library automatically. You may specify the turbojpeg library path manually.
Jul 20 05:09:24 DietPi Home Assistant[569]: e.g. jpeg = TurboJPEG(lib_path)
Jul 20 05:09:26 DietPi Home Assistant[569]: 2026-07-20 05:09:26.731 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'default_config'. Setup failed for dependencies: ['bluetooth', 'usb']
Jul 20 05:09:26 DietPi Home Assistant[569]: 2026-07-20 05:09:26.731 ERROR (MainThread) [homeassistant.setup] Setup failed for 'default_config': Could not setup dependencies: bluetooth, usb
Jul 20 05:09:33 DietPi Home Assistant[569]: 2026-07-20 05:09:33.659 ERROR (MainThread) [homeassistant.components.homeassistant_alerts.coordinator] Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1082)')]
Jul 20 05:09:33 DietPi Home Assistant[569]: 2026-07-20 05:09:33.785 ERROR (SyncWorker_0) [aiodhcpwatcher] Cannot watch for dhcp packets without a functional packet filter: libpcap is not available. Cannot compile filter !
Jul 25 07:14:37 DietPi Home Assistant[569]: 2026-07-25 07:14:37.957 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'esphome'. Setup failed for dependencies: ['bluetooth']
