Difficulty setting GPU memory split
  • DietPi version | 10.1.2
  • Distro version | trixie 0
  • Kernel version | 6.12.75
  • Architecture | arm64
  • SBC model | RPi 5 Model B (8G)
  • Power supply used | 27W RPi PSU
  • SD card used | amazonbasics 128G U3 microSD
  1. Install DietPi
  2. Set gpu memory split in dietpi-config to 96
  3. Check GPU memory: vcgencmd get_mem gpu
  • vcgencmd get_mem gpu returns gpu=96M
  • vcgencmd get_mem arm returns arm=8096M
  • vcgencmd get_mem gpu returns gpu=8M
  • vcgencmd get_mem arm returns arm=1016M
  • This post might be related.
  • Afterwards, I tried setting gpu_mem manually in /boot/firmware/config.txt, but vcgencmd still gives the same values. This does update what’s said in dietpi-confighowever.
Snippet from /boot/firmware/config.txt:
#-------GPU memory splits-------
gpu_mem_256=256
gpu_mem_512=256
gpu_mem_1024=256
gpu_mem=256
I don’t know if vcgencmd is reporting incorrectly, or if my GPU memory split isn’t actually being adjusted. I don’t know how to check either. The whole reason I’m trying to adjust this in the first place is because I can’t manage to watch videos of any resolution. I’ve already ruled out CPU throttling, browser, internet, and microSD performance.
Any help would be appreciated. Thanks.
VideoCore VII allocates the memory dynamically, so vcgencmd just shows nonsense.
https://forums.raspberrypi.com/viewtopic.php?t=366298
Ohhh, that explains it. Thanks!
