I DON’T really needs GUI-integrated tools if i can solve the
│ WiFi : Not Found | [On] | Disconnected │
with out the need for network-manager
Then you can switch onboard WiFi on via dietpi-config and end users can then use it to actually scan and enter WiFi credentials for their SSID.
i’m thankful for your help the problem is that no matter what i do dietpi-config is not showing that found device and or being capable to scan for network when i do scan it splash screen and go back to adaptter settings and even i put wi-fi setup byhand it keeps showing │ WiFi : Not Found | [On] | Disconnected │
Did you reboot the system once onboard WiFi has been activated? Can you share ip a after a reboot happen?
pls can you share following
ip a
what is the name of the adaptor number 5?
the adaptor number 5 ( mlan0 ) i think this is why it’s not working it should be
wlan0
it’s the driver
Ok this read me might have answer
https://android.googlesource.com/kernel/msm/+/android-wear-5.1.1_r0.10/drivers/net/wireless/mwifiex/README
But how to make it work within the first time setup
in Surface RT i dont have the third line in the adapter options at all
(Onboard wifi )
The option is shown on RPI boards only, if I’m not mistaken.
I guess you need to add/activate the driver before creating an image
At least our script explicitly expect a WiFi adaptor called wlan0.
Hmm, mlan seems to be a different adapter type, but I couldn’t nail it down. I’ll give you an interfaces config when I’m home to try bringing it up that way instead of via dietpi-config.
Does this exist?
ls -l /sys/class/net/mlan0/wireless
Try the following:
cat << '_EOF_' > /etc/network/interfaces.d/mlan0.conf
allow-hotplug mlan0
iface mlan0 inet dhcp
wireless-power off
_EOF_
sed -i '/local wifi_iface=/c\local wifi_iface=mlan0' /boot/dietpi/func/dietpi-wifidb
dietpi-wifidb # try to scan for SSIDs and configure one
ifup mlan0
thank you
i will inform you with results as soon i do it . im on trip today i can’t work on the device
Oky now we can move to the next stage.
can we make this 2 orders to start using Automation_Custom_PreScript.sh
cp -r kernel-modules/lib/* /lib/
cp -r /boot/mlan0.conf/ /etc/network/interfaces.d/
please
Jep, this will work. Don’t forget to add a shebang:
#!/bin/dash
cp -r /path/to/kernel-modules/lib/. /lib/
cp /path/to/mlan0.conf /etc/network/interfaces.d/
Adjust /path/to with the location where you store those files… If they are on a dedicated drive, it needs to be mounted first. If it’s not on a dedicated drive, of course you could place them to the right directory in the first place
how to
you know it should run as root user to edit root volumes
