I have installed DietPI and LXDE on a Odroid C2; I have also read the manual tha WLAN connections are meant to be added by editing the parameters in the proper text file in the /boot directory.
Hoever what I would really want is a graphical tool like WICD.
Have you tried to install WICD for WLAN management and if yes, does it work properly ?
you could use “dietpi-config” tool to manage your wifi settings. It’s as well some kind of of interface. No need to go down to config files. It’s working as well without a graphic desktop enthronement
┌──────────────────────────────────────────────────┤ DietPi-Config ├───────────────────────────────────────────────────┐
│ Please select an option to change: │
│ ●─ Adapter Options ──────────────● │
│ Ethernet : Available | [On] | Connected │
│ WiFi : Not Found | [Off] | Disconnected │
│ Onboard WiFi : [Off] │
│ ●─ Additional Options ───────────● │
│ IPv6 : [Off] │
│ Proxy : [Off] │
│ Test : Run internet connection test │
│ <Ok> <Back> │
