DietPi v9.11.2 - problem after fresh install with Portainer Templates
Hello , what can that be , after a fresh install i tried to configure my templates in Portainer
and all works, it shows me the amount of templates- but when clicking on anyone the site opens for 2 seconds or less and closes immideately so i can not deploy anything or go on further.
On other maschines (Proxmox , raspberry 3 B+) after updates there is no Problem.
My Hard and Software :
Argon One Case
Device model : RPi 4 Model B (aarch64)
DietPi v9.11.2 : 09:40 - Mo 24.02.2025
Portainer Business Edition
Server Version: 2.27.0 LTS
Database Version: 2.27.0
*Same Problem with the Community Editon.
All installed over the Dietpi-Software Center. (Docker ; Portainer ; Docker-Built…)
I tried different addresses and browser:
f.e. : For the template
https://raw.githubusercontent.com/pi-hosted/pi-hosted/master/template/portainer-v2-amd64.json
etc.
but there is always the same Problem:
The site closes after showing itself in 2 seconds to the overview of the Templates
has anyone any idea what can that be or has/had the same Problem ?
This is inside portainer? Maybe something to check with Portainer developer. From our side we just deploy the container as provided by portainer guys
Thanks to you Joulinar, I just found a post about it.
Unable to Install Template or Edit Configuration - Portainer Community Edition 2.27.0 LTS · Issue #75 · Lissy93/portainer-templates · GitHub ]]([ Unable to Install Template or Edit Configuration - Portainer Community Edition 2.27.0 LTS · Issue #75 · Lissy93/portainer-templates · GitHub
What Portainer has done here is really bad and there is no solution in sight - but this is not a problem from DietPi!
thx for sharing
