DietPi v6.28.0, RPi Zero W, gpio-shutdown not working
I have just done a new install of DietPi v6.28.0 on a RPi Zero W.
After the updates and setup etc, I added the following line to config.txt (ie sudo nano /DietPi/config.txt):-
dtoverlay=gpio-shutdown,gpio_pin=20,active_low=1,gpio_pull=up
After a reboot, pressing the button that I have connected to GPIO20 and GND, nothing happens.
I am using GPIO20 because I require I2C and I2C uses GPIO2 and GPIO3.
I am using the same method of shutdown on a RPi3 that has been upgraded a couple of times to DietPi v6.28.0 (cannot remember which version it started out on) and it works as designed.
Could someone suggest where I should start looking as to why this is not working?
Regards,
John
OK. It’s been a while but I have found the solution.
Apparently systemd-logind is masked and blocks the detection of a shutdown signal.
more info in this page:-
https://dietpi.com/forum/t/dietpi-survey-information/32/1
The way to fix the problem is to:-
1 - Change the following line in dietpi.txt before first boot.
Unmask (enable) systemd-logind service (including dbus), which is masked by default on DietPi
AUTO_UNMASK_LOGIND=0
to
AUTO_UNMASK_LOGIND=1
OR
2 - If you have completed installation, do the following commands:-
sudo apt install dbus
sudo systemctl unmask systemd-logind
sudo systemctl start systemd-logind
I hope this helps someone out.
Regards,
John
