DietPi version | G_DIETPI_VERSION_CORE=8 G_DIETPI_VERSION_SUB=11 G_DIETPI_VERSION_RC=2 G_GITBRANCH='master' G_GITOWNER='MichaIng' G_LIVE_PATCH_STATUS[0]='not applicable'
Distro version | bullseye
Kernel version | Linux DietPi 5.15.80-rockchip64 #22.11.1 SMP PREEMPT Wed Nov 30 11:12:47 UTC 2022 aarch64 GNU/Linux
SBC model | ROCK64 (aarch64)
Power supply used | Default barrel one that was sold in the store.
SD card used | 64 gb microsd class1
Software title | N/A (Well, technically alsamixer)
Can this issue be replicated on a fresh installation of DietPi? Yes.
Install the image to the sd card.
FInish setup in the device. Select the sound device in dietpi-config.
Never any sound. There is not even sound systray icon.
Sound.
No sound.
AlsaMixer reports that neither HDMI or JackAnalog have βany controlsβ.
Everything is well and nice, os updated and upgraded. alsamixer installed properly.
Update: PulseAudio was installed and it never loads. It is stuck in βEstablishing connection to pulseaudio, please waitβ¦β
DietPi-JustBoom
βββββββββββββββββββββββββββββββββββββββββββββββββββββ
Mode: ALSA Output Info
closed
closed
[ OK ] DietPi-JustBoom | Completed, press any key to exit...
These do not output anything in the terminal. I thought so that it was a driver error, sadly my linux knowledge is really basic. Is there a way to implement the audio driver without having to massacre the current installation?
Applied these commands as instructed.
Rebooted, but nothing has changed. There is still no sound, ALSA reports no controls, cannot add volume plugin to traybay, and no volume software opens up.
This has been solved with the legacy kernel. Alsa reports now:
rk-hdmi
rk-i2s
rk-spdif
Thereβs sound now in my monitor speakers. Although, it still says there are no controls, so, no volume control as a caveat, but much better than no sound at all. Thank you!
