- DietPi version | cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=16
G_DIETPI_VERSION_RC=2
- Distro version | echo $G_DISTRO_NAME $G_RASPBIAN
bullseye 0
- Kernel version | uname -a
- Architecture | dpkg --print-architecture
arm64
- SBC model | echo $G_HW_MODEL_NAME or (EG: RPi3)
RPi 4 Model B (aarch64)
- Power supply used | (EG: 5V 1A RAVpower)
5V 1A
- SD card used | (EG: SanDisk ultra)
SanDisk Extreme 64Go
- Software title | Hotspot
- Was the software title installed freshly or updated/migrated? update
d7d5e504-5697-40f1-a8d8-20a7d39a0e7f - Bug report ID |
echo $G_HW_UUID
**dietpi@DietPi:~$ cat /etc/network/interfaces**
# Drop-in configs
source interfaces.d/*
# Ethernet
allow-hotplug eth0
iface eth0 inet static
address 192.168.0.100
netmask 255.255.255.0
gateway 192.168.0.254
#dns-nameservers 9.9.9.9 192.168.0.100
# WiFi
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.42.1
#gateway 192.168.0.1
#dns-nameservers 9.9.9.9 149.112.112.112
pre-up iw dev wlan0 set power_save off
post-down iw dev "wlan0 set power_save on
# iptables NAT rules
up iptables-restore < /etc/iptables.ipv4.nat
up ip6tables-restore < /etc/iptables.ipv6.nat
**dietpi@DietPi:~$ cat /etc/default/isc-dhcp-server**
INTERFACESv4="wlan0"
mai 06 08:37:38 DietPi dhcpd[3911]: No subnet declaration for wlan0 (no IPv4 addresses).
mai 06 08:37:38 DietPi dhcpd[3911]: ** Ignoring requests on wlan0. If this is not what
mai 06 08:37:38 DietPi dhcpd[3911]: you want, please write a subnet declaration
mai 06 08:37:38 DietPi dhcpd[3911]: in your dhcpd.conf file for the network segment
mai 06 08:37:38 DietPi dhcpd[3911]: to which interface wlan0 is attached. **
mai 06 08:37:38 DietPi dhcpd[3911]: Not configured to listen on any interfaces!
mai 06 08:37:38 DietPi dhcpd[3911]: If you think you have received this message due to a bug rather
mai 06 08:37:38 DietPi dhcpd[3911]: than a configuration issue please read the section on submitting
mai 06 08:37:38 DietPi dhcpd[3911]: bugs on either our web page at www.isc.org or in the README file
mai 06 08:37:38 DietPi dhcpd[3911]: before submitting a bug. These pages explain the proper
mai 06 08:37:38 DietPi dhcpd[3911]: process and the information we find helpful for debugging.
mai 06 08:37:38 DietPi dhcpd[3911]: exiting.
mai 06 08:37:38 DietPi kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
mai 06 08:37:38 DietPi hostapd[3895]: wlan0: interface state UNINITIALIZED->ENABLED
mai 06 08:37:38 DietPi hostapd[3895]: wlan0: AP-ENABLED
mai 06 08:37:38 DietPi systemd[1]: Started Access point and authentication server for Wi-Fi and Ethernet.
**dietpi@DietPi:~$ ip a**
inet6 ::1/128 scope host
link/ether dc:a6:32:83:31:28 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.100/24 brd 192.168.0.255 scope global eth0
inet6 fe80::dea6:32ff:fe83:3128/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether dc:a6:32:83:31:2c brd ff:ff:ff:ff:ff:ff
inet6 fe80::dea6:32ff:fe83:312c/64 scope link
IP address on the wlan0 does not remain
**dietpi@DietPi:~$ sudo cat /etc/hostapd/hostapd.conf**
interface=wlan0
driver=nl80211
ssid=DietPi-HotSpot
hw_mode=g
channel=3
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=XXX
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
ieee80211n=1
country_code=FR
Hi, I use my raspberry pi as a wifi hotspot pihole.
everything worked fine until now. but since a few days following an update I think. the wifi hotpspot is no longer recognized
