When I install the dashboard it doesn’t start, it gives me failed
root@DietPi:~# systemctl status dietpi-dashboard
× dietpi-dashboard.service - Web Dashboard (DietPi)
Loaded: loaded (
ce/etc/systemd/system/dietpi-dashboard.service; enabled; preset:
enabled)
Active: failed (Result: signal) since Tue 2024-02-27 11:05:05 GM
T; 2min 25s ago
Duration: 12ms
Process: 4511 ExecStart=/opt/dietpi-dashboard/dietpi-dashboard (code
=killed, signal=SEGV)
Main PID: 4511 (code=killed, signal=SEGV)
CPU: 772us
feb 27 11:05:05 DietPi systemd[1]: Started dietpi-dashboard.service - Web Dashboard (DietPi).
feb 27 11:05:05 DietPi systemd[1]: dietpi-dashboard.service: Main process exited, code=killed, status=11/SEGV
feb 27 11:05:05 DietPi systemd[1]: dietpi-dashboard.service: Failed with result 'signal'.
did you tried the nightly build or is it stable?
Jappe
27 February 2024 12:02
4
Runs on my test Pi
root@TestPi3B:~# systemctl status dietpi-dashboard
● dietpi-dashboard.service - Web Dashboard (DietPi)
Loaded: loaded (/etc/systemd/system/dietpi-dashboard.service; enabled; preset: enabled)
Active: active (running) since Tue 2024-02-27 13:00:57 CET; 25s ago
Main PID: 1249 (dietpi-dashboar)
Tasks: 2 (limit: 985)
Memory: 2.9M
CPU: 272ms
CGroup: /system.slice/dietpi-dashboard.service
└─1249 /opt/dietpi-dashboard/dietpi-dashboard
You are running a RPi 5, right?
Can you check
journalctl -u dietpi-dashboard
yes Pi5
[ OK ] DietPi-Software | systemctl start dietpi-dashboard
root@DietPi:~# journalctl -u dietpi-dashboard
feb 27 12:14:25 DietPi systemd[1]: Started dietpi-dashboard.service - Web Dashboard (DietPi).
feb 27 12:14:25 DietPi systemd[1]: dietpi-dashboard.service: Main process exited, code=killed, status=11/SEGV
feb 27 12:14:25 DietPi systemd[1]: dietpi-dashboard.service: Failed with result 'signal'.
Jappe
27 February 2024 12:23
6
Ok that’s everything, hmm.
Let’s ask the dev @ravenclaw900
maybe you can also increase log level and try again and check journalctl.
G_CONFIG_INJECT 'log_level[[:blank:]]' '#log_level = "debug"' /opt/dietpi-dashboard/config.toml
systemctl restart dietpi-dashboard
edit:
to switch to nightly just trigger a reinstall
dietpi-software reinstall 200
Try the nightly build if on RPi5
When it asks me during the installation if I want a backend or not, what do I put?
okaaaayy its works thanks the nightly works very good
I only have a couple of problems left.
The version that it installs is 0.6.1 and it tells me that there is a new 0.6.2 but doing the 200 reinstall does not update it.
The other problem is when I use the file manager of this dashboard to download a movie to my PC, it doesn’t download, it keeps saying zipping…
and nothing goes down
Pls use the DietPi Dashboard Github account for such request. There you will reach the Dashboard developer @ravenclaw900 GitHub - ravenclaw900/DietPi-Dashboard: A lightweight, standalone web dashboard for DietPi
system
Closed
27 May 2024 14:15
12
