DietPi Backup problem
Is it possible that dietpi-backup still works when started manually, but the automated process isn’t working? When I configure dietpi-backup, I specify the backup path, the number of backups to retain, and a daily schedule. However, I haven’t been able to find a cron entry for this. Everything is explained clearly in the documentation, but it doesn’t seem to be working for me.
For now, I’ve been using raspiBackup as a workaround.
I’d appreciate a quick update on whether this feature is working or has limited functionality.
there is no cron entry. It’s done via /etc/cron.daily/dietpi
Feature works as expected, I do daily backups with this for years.
It’s also mentioned that it works via /etc/cron.daily/dietpi.
@Joulinar, @Jappe
OK, then I’ll have a closer look at that.
Thanks
