] I have searched the existing open and closed issues
- DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=9
G_DIETPI_VERSION_RC=0
G_LIVE_PATCH_STATUS[2]=‘not applicable’
G_LIVE_PATCH_STATUS[3]=‘not applicable’
- Distro version |
bookworm 0
- Kernel version |
uname --all
Linux JuicyPi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
- Architecture |
dpkg --print-architecture
arm64
- SBC model |
Pi Zero 2W (AARCH64)
- Power supply used | (EG: 5V 1A RAVpower)
standard power supply
- SD card used | (EG: SanDisk ultra)
SanDisk Ultra 64GB
- Software title | (EG: Nextcloud) PiHole/Unbound
- Was the software title installed freshly or updated/migrated? All software updated
- Can this issue be replicated on a fresh installation of DietPi? Trying to solve issue before trying
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID |
echo $G_HW_UUIDb2b07f9f-efda-4a6b-a91b-fc6ce5af05d2
Installed and setup Pi-hole and Unbound on DietPi. I accidentally installed Apache instead of Lighttpd. I fixed that issue and uninstalled Apache and installed/enabled lighttpd. My ports are not showing correct port numbers.
ss -tulpn | grep LISTEN
tcp LISTEN 0 5 127.0.0.1:4711 0.0.0.0:* users:(("pihole-FTL",pid=65220,fd=10))
tcp LISTEN 0 1024 0.0.0.0:80 0.0.0.0:* users:(("lighttpd",pid=46410,fd=5))
tcp LISTEN 0 256 127.0.0.1:5335 0.0.0.0:* users:(("unbound",pid=65841,fd=4))
tcp LISTEN 0 1000 0.0.0.0:22 0.0.0.0:* users:(("dropbear",pid=403,fd=3))
tcp LISTEN 0 32 0.0.0.0:53 0.0.0.0:* users:(("pihole-FTL",pid=65220,fd=5))
tcp LISTEN 0 1024 [::]:80 [::]:* users:(("lighttpd",pid=46410,fd=4))
tcp LISTEN 0 1000 [::]:22 [::]:* users:(("dropbear",pid=403,fd=4))
tcp LISTEN 0 32 [::]:53 [::]:* users:(("pihole-FTL",pid=65220,fd=7))
I also cannot access my Verizon router’s network settings website (mynetworksettings.com). I could prior to switching to lighttpd. Pinging and nslookup yields no results/cannot be reached.
Pi-Hole should have ports 67, 547, 4711. Based on required ports. Not all hardware has switched to Pi-hole for dns. Unbound doesn’t seem to be working and seems misconfigured.
Unbound misconfigured and nslookup yields 127.0.0.1 instead of 192.168.1.194. Pi-hole missing required ports.
EDIT: Just tried this:
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 73268/pihole-FTL
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 73406/lighttpd
tcp 0 0 127.0.0.1:5335 0.0.0.0:* LISTEN 73137/unbound
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 73268/pihole-FTL
tcp6 0 0 :::80 :::* LISTEN 73406/lighttpd
tcp6 0 0 :::53 :::* LISTEN 73268/pihole-FTL
udp 0 0 127.0.0.1:5335 0.0.0.0:* 73137/unbound
udp 0 0 0.0.0.0:53 0.0.0.0:* 73268/pihole-FTL
udp6 0 0 :::53 :::* 73268/pihole-FTL
