DietPi 9.11.2 changes Pi-Hole default web server port to 8089 makes web UI inaccessible without specifying port
When updating to DietPi 9.11.2 with Pi-Hole (v6) installed, there’s a prompt to change web ui port from default to 8089. If I accept this change, it will make web UI inaccessible if I don’t specify the new port.
I had to change webserver.ports back to default 80o,443os,[::]:80o,[::]:443os in /etc/pihole/pihole.toml. This should be better documented in either DietPi changelog or in Pi-Hole documentation.
Yes this is done by purpose. As well during the update you got the information within the prompt on how to switch back.
Our first aim was to integrate PiHole v6 support. Docs will be updated soon as well.
