Dietpi 9.1.1 Bookworm Raspi 3a+ config setting dtparam=audio=on and dtoverlay=vc4-fkms-v3d is installed sdl2 Amiberry sound is there after reboot sound problems with slight jerking I end it with quit this picture comes up what can I do with it It will work in the future, thank you (vc4 error Async flips arent allowed)
I wonder if you changed it to vc4-kms-v3d rather than the fkms will change anything
https://forums.raspberrypi.com/viewtopic.php?p=1507622#p1507247
I had it on kns before but I can’t get a sound sound in amiberry or somewhere else and dauraf I switched to fkms then get the error and stutter in the sound
btw: the picture is not readable at all.
It’s described above what it’s about
