Hi Forum! How are you? Long time no see…
I’m having trouble running the most simple cron job.
I’ve added the following by entering
crontab -e
(as root):
20 12 * * * /bin/date > /tmp/date.log
But nothing’s happening. I also tried putting a new file „date“ into /etc/cron.d/ but nothing’s happening as well.
The exact same thing on another server running Ubuntu (20.04.2 LTS) runs the job with no issues.
I’m lost, as the other jobs in cron.d/ (php, pihole, rsnapshot) run fine…
Thanks for any suggestions
Okay… restarting the cron.service does the job for aforementioned command.
What I really want to do is resetting my Wireguard connection by doing:
36 17 * * * '/usr/bin/wg-quick down' && '/usr/bin/wg-quick up'
This does not work.
I would recommend to restart the service instead of trying to sop/start Wireguard
/bin/systemctl restart wg-quick@wg0.service
Hi Joulinar,
thanks for your suggestion! This seems to have worked
Could you enlighten me, why that’s the case compared to wg-quick up?
Thanks!
I guess you missed to specify the interface name for Wireguard to start/stop. At least the service is doing nothing else as you did, just with an interface name specified.
ExecStart=/usr/bin/wg-quick up %i
ExecStop=/usr/bin/wg-quick down %i
ExecReload=/bin/bash -c 'exec /usr/bin/wg syncconf %i <(exec /usr/bin/wg-quick strip %i)'
variable %i is specified within the service name wg-quick@wg0 right after @. Means, the interface name is wg0
