I added two users with command:
useradd usera
useradd userb
Mountet external USB on test8g but you can see that on lsblk that USB drive is in /mnt/test8 WITHOUT LETTER G in the end.
Should I try ProFTPD and save us the time, if ProFTPD can do all that I asked?
[global]
workgroup = WORKGROUP
server string = %h server
dns proxy = no
max log size = 1000
syslog only = no
syslog = 0
panic action = /usr/share/samba/panic-action %d
security = user
encrypt passwords = true
passdb backend = tdbsam
obey pam restrictions = yes
unix password sync = yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
pam password change = yes
map to guest = bad user
load printers = no
printcap name = /dev/null
disable spoolss = yes
[dietpi]
comment = DietPi Share
path = /mnt/test8g/usera/
browseable = yes
create mask = 0664
directory mask = 0775
valid users = dietpi
writeable = yes
max connections = 8
# Please use "dietpi-drive_manager" to setup mounts
# NETWORK
# TMPFS
tmpfs /tmp tmpfs size=1024M,noatime,lazytime,nodev,nosuid,mode=1777
tmpfs /var/log tmpfs size=50M,noatime,lazytime,nodev,nosuid,mode=1777
# MISC: ecryptfs, vboxsf (VirtualBox shared folder), gluster, bind mounts
# SWAPFILE
/var/swap none swap sw
# PHYSICAL DRIVES
PARTUUID=907af7d0-02 / ext4 noatime,lazytime,rw 0 1
PARTUUID=907af7d0-01 /boot vfat noatime,lazytime,rw 0 2
UUID=ed666cfd-195a-49b5-8489-ad746ef9d185 /mnt/test8g ext4 noatime,lazytime,rw,nofail,noauto,x-systemd.automount
#UUID=9569-6A93 /mnt/9569-6A93 vfat noatime,lazytime,rw,nofail,noauto,x-systemd.automount
NAME FSTYPE LABEL SIZE RO TYPE MOUNTPOINT PARTUUID UUID
sda 7.3G 0 disk
├─sda1
│ ext4 7.3G 0 part /mnt/test8 0c0c0833-716b-40b7-9fb3-ac802039d3e7 ed666cfd-195a-49b5-8489-ad746ef9d185
└─sda2
vfat UEFI_NTFS
256K 0 part f647a085-6ef7-49ef-999f-44ed9d24f109 9569-6A93
mmcblk0
│ 28.9G 0 disk
├─mmcblk0p1
│ vfat boot 256M 0 part /boot 907af7d0-01 4AD7-B4D5
└─mmcblk0p2
ext4 rootfs
28.6G 0 part / 907af7d0-02 2887d26c-6ae7-449d-9701-c5a4018755b0
total 28
drwxr-xr-x 7 root root 4096 Jan 5 13:20 .
drwxr-xr-x 21 root root 4096 Sep 10 14:30 ..
drwxrwxr-x 10 dietpi dietpi 4096 Dec 27 15:20 dietpi_userdata
drwxrwxr-x 2 dietpi dietpi 4096 Sep 10 14:28 ftp_client
drwxrwxr-x 2 dietpi dietpi 4096 Sep 10 14:30 nfs_client
drwxrwxr-x 2 dietpi dietpi 4096 Jan 4 18:53 samba
drwxrwx--- 4 root root 4096 Jan 5 13:28 test8g
root@DietPi:/mnt# ls
dietpi_userdata ftp_client nfs_client samba test8g
