Creating an issue
DietPi version |
cat /boot/dietpi/.version:
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=11
G_DIETPI_VERSION_RC=2
G_GITOWNER=‘MichaIng’ -
Distro version |
bookworm -
Kernel version |
uname --all
Linux NanoPi-Zero2 6.1.99 #35 SMP Mon Feb 10 19:14:13 CST 2025 aarch64 GNU/Linux -
Architecture |
dpkg --print-architecture
arm64 -
SBC model |
Generic Device (aarch64) -
Raspberry Pi 27W USB-C Power Supply -
N/A
I understand completely that I am “On My Own”, having run the conversion script on the NanoPi Zero2 image rk3528-eflasher-debian-bookworm-core-6.1-arm64-20250211.img. However, the conversion was near faultless and this, to me, was truly impressive.
I wanted to run abcde to rip CDs and most of the packages that I needed were available. The only ones that I could not install using APT were:
librockchip-mpp1 and
librga.so
I found no easy way of installing these in what I consider to be a “clean” way using APT so I copied the files from the original image. I note that https://dietpi.com/forum/t/dietpi-v6-33/4548 was missing for Kodi on Odroid XU4 so it may be a little more widely required.
- abcde CD ripper- dependent on these two libraries
I understand completely that this converted image is unsupported (However, the conversion script is brilliant!)
- apt install abcde
- Attempt to run abcde
- abcde runs to rip CDs
- Error messages indicating missing libraries
